Farmboy
- Joined
- Jul 29, 1999
- Location
- Bloomington (Minneapolis), MN, USA
- TDI
- '15 Golf SE TDI 6spd 109k miles; '00 A4 NB 5spd 216k; '96 B4 Passat Sedan 220k
I think I've done my due diligence, reading the Bentley manual, reading the A4 TB change guide listed, researched the forums, etc. I waded into the 60k TB change on my wife's 2000 New Beetle TDi.
Still - even after solidly establishing my position as the person who will perform the longest timing belt change ever - I find myself facing a problem and an issue:
Problem: I can't remove water pump. I have the TB, cam sprocket, tensioner, idler, and 3 water pump bolts out. Can anyone tell me WHAT AM I MISSING?
Issue: I can't possibly see the timing marks on the flywheel. If you have a manual transmission do you just go ahead and remove the waterline (below the vacuum pump and containing 3 glow plugs) that's in the way (I did see that Mickey's TB change post from a couple of years ago indicated that he did just that), do you somehow bend light, or are you just able to take care of business without actually referencing the marks . . . Again, can someone tell me WHAT AM I MISSING?
Now to go back to beating my head against the garage floor.
Humble thanks in advance
Tom
Tom
