tdiblair
- Joined
- May 16, 2005
- Location
- CT Yankee
- TDI
- Passat 2005 silver Passat Sedan & 2005 Wagon Stone Henge Gray
On a well done MoGolf outer CV boot repair PDF. It's my own lack of knowledge to understand two terms, of a extremely organized PDF. There is that large bolt at the very end of our front axles ( dead center to our wheel lug nuts) when we remove our front axels to generally replace the entire front axel . In my case I'm just replacing with a R.L. Axel assembled exchange and want to get the torque setting of that single bolt right.
At the very end of the " how to " PDF MoGolf writes:
How do I tell the difference between the M16 bolt joint or the M14? is the M16 the one that uses a hex socket to remove/tighten and the M14 the one that uses the big 'Allen' head to remove and tighten?
tdiblair
"Install the large bolt finger tight. Install the wheel and tighten bolts to 120 Nm.
Put the back on the ground. Tighten the new large bolt to 190 Nm plus half a turn if it is
an M16 bolt joint. Tighten to 115 Nm plus half a turn if it is an M14 bolt. Yes, that is
very tight."How do I tell the difference between the M16 bolt joint or the M14? is the M16 the one that uses a hex socket to remove/tighten and the M14 the one that uses the big 'Allen' head to remove and tighten?
tdiblair
