Dieselgate warranty info.
Drclaw
ME
2014 Jetta Sportwagen
I'm trying to figure out exactly when my diesel gate warranty will expire. I know it's 10 years after what? Initial purchase date or mfg date? I checked the vin on the warranty info page on VW.com but it just shows my car received the repair oct2018. I purchased it second hand , nov 2018. Not sure what the original sale date is but think I got a Carfax that shows it from the used car lot I got it from.
DrGERTol
NW OH
2011 Golf Variant (JSW) 6MT
@Drclaw -- The original emissions warranty ran for 10 years from the in-service date or 120K miles -- the extended emissions warranty due to dieselgate runs concurrently, so that the emissions warranty in effect is the greater/longer of the two. Your local VW service advisor can look up the in-service date for the VIN (along with all the PR codes) -- though your Carfax should indicate this, too, as the initial sales date. --g
You can often guess as to the close in-service date based on the manufactured date on the tag in the door jam. If it was a Mexican or American built car, it was usually sold within a month or two of then. Something that came from Europe usually will be closer to three months. Most TDIs didn't sit on dealer lots for very long.
Drclaw
ME
I think this is where I previously saw a date because I've been using April 2024 as a notional date.
pkhoury
That guy with the goats
Medina, TX
There's a website where you can plug in the VIN. We got lucky; the 2011 JSW I had my girlfriend buy is covered for a hair over 5,000 miles. Just enough for me to get the flywheel done (because I'm not pulling a 200+ pound DSG in triple digit heat), drive back and head straight to the dealer for a new DPF (because it's bad).
DrGERTol
NW OH
@Drclaw -- In our case, the ELSA record for our MY11 SportWagen shows MX production date 30 Aug 2010 & delivery (sales) date 12 Feb 2011; VWoA used the Feb 2011 date for our corrosion warranty claim that was submitted initially in Jan '22 and completed in Apr '23. --g
Drclaw
ME
Link? Only website I found that used a VIN showed when the mod was done
pkhoury
Medina, TX
I believe that's it, and it should tell you how long your warranty is good for, from the date/mileage you got the mod done. I was lucky and the PO at some point did it in I think 2020 or 2021. Otherwise, I would've recycled the DPF.
DrGERTol
NW OH
@Drclaw -- If the VW site shows the emissions mod was done in Oct '18, you're well past the dieselgate warranty now (ended Oct '22 for AT, Apr '23 for 6MT). If you're still under 120K miles, you need to determine the date the car was first sold (that is, its "in-service" date) for the original emissions warranty -- your local service advisor (or Carfax) can tell you that. --g
Correct, the website does not tell you the original in-service date. Which is dumb, because they obviously have that information, why they didn't just put that into that warranty check is beyond me. Still lots of 2014 and 2015s (and a smattering of 2016 V6s) that will still be under the 10+ year warranty for a bit yet.
Drclaw
ME
Concur with your observations. I'm only at 86k so the time from in service will be the gating factor for me
