Dieselgate, The Canadian Edition
GoFaster
Moderator at Large
Brampton, Ontario, Canada
2006 Jetta TDI
I would have to disagree. People show up at DriveClean tests every day in Ontario, to be told that they can no longer register the car unless they make thousands of dollars in repairs. Often, these people are the poorest in society, and buying a $1000 catalytic converter is a hardship to them.
It is quite likely that the Ontario government would say "VW offered to buy the car back. You declined. Your choice. You may no longer register it in Ontario, as it does not meet emissions."
This is only a foreseeable situation AFTER that remedy has been rolled out and owners have been given a reasonable amount of time to react to it (i.e. until the end of the buyback / fix campaign - whenever that might happen to be).
As of right now, if you have a common-rail TDI that is subject to having a Drive Clean test, it is supposed to be treated the same as any other car: If the "check engine" lamp is not on, and "readiness" is set internally, it is good to go - despite any underlying shenanigans that VW may have done which are NOT the owner's fault.
Go to the Drive Clean website and look it up yourself if you don't believe me. As of right now - No problem to have a Drive Clean done on a TDI and the underlying shenanigans are not a factor.
GoFaster
Moderator at Large
2006 Jetta TDI
Sorry, I have not been following all the discussion about the buyback program. There is no information at https://www.vwcanadasettlement.ca/en/.
Could someone simply tell me if there is any new update regarding the buyback program since the 31st of March?
PLEEEEEEASE go back a few posts and do some reading to avoid 18,367 individual repetitions of "Sorry, I have not been following. Are there any updates?"
This has already happened several times in this thread and I, for one, am getting fed up with people failing to do even the most basic reading before posting. Sorry for you being the victim of my rant, but it is what it is.
uchu
Markham ON
2012 Passat Highline - in VW's possession
iantryinit
Canada
2009 Jetta TDI, 2013 Passat TDI
Agree with your reply but.........if there wasn't so much BS in this thread and it was strictly about facts on Canadian scandal I'm sure everyone would read each post.
I just logged on for first time in awhile and seems like endless pages of useless banter and not too many facts.
But that's just my opinion.
Bajszi
Redvers, SK Canada
2011 Golf SW
I agree with you. That's why I'm trying to read it daily, so I can filter out all those pointless discussions. I don't think there was any useful info since post #3281 on Page 219.
Cheers,
Bajszi
ElectricMayhem
Ontario, Canada
None!
I have to disagree with you ... it shows you are not into politics .. :) ... This would be quite suicidal, especially for bottom-of-the-barrel popularity of Wynn.
Very few people will be affected because 99% of owners are having an orgy on Facebook discussing their upcoming trip to the top of the vehicle depreciation curve. The citiots will cheer her because they have read the "forty times" stupidity, not realizing that it is forty times a microscopically small number.
It is likely that they grandfather TDi's in for licensing but they may also hold that to the current owner and when you try to sell it the ownership will not be transferable.
That is very insightful, and is a definite possibility. The Liberal government did something similar with firearms - you can own certain firearms until you die, then they are confiscated from your estate, to be melted down.
Nowhere it says, that I should be carrying the burden in such a case by not being able to register my vehicle.
You guys are looking at the wrong thing. The only thing you should be looking at is the Environmental Protection Act. It says no-one may cause an out-of-compliance vehicle to be driven on a public road. End of story. The fact that TDIs pass today is simply a limitation of the way they have chosen to do the test. The engine type is coded into the VIN, and it would take about ten minutes for a faceless bureaucrat to program a computer to write a letter to all the owners saying "Dear tax slave: sorry, but you can't renew your sticker any more. It is for the children, we are sure you understand."
You can point to your passed DriveClean certificate all you want, it will do you no good in the end. VW has already pled guilty, the fact that the cars were never in compliance, is not in question.
tobianogreg
Kamloops BC Canada
2013 Jetta returned
Does anyone have an idea of why the mileage catagories shifted on the CBB estimator site? Will they change every 1st of the month?
I just dropped back into a higher payout catagory but will lose that if I drive another 940 kms (this month?).
ElectricMayhem
Ontario, Canada
None!
I would not obsess about the "estimator." It is not a part of the settlement; not binding on VW in any way. It is just to entertain you while the lawyers figure out how they are going spend the $150mm they "earned" for the truly outstanding job they did.
Armby
Ottawa, Canada
2013 Golf
The ranges should go up in time to reflect the average mileage driven by each model year. Dangerous predicting if this will happen the 1st of every month because VW has not been forthcoming on the details.
Having said that everything could change if the Judge forces a reset by not approving the deal as is.
n1d0n
canada
2013 golf tdi wolfsburg and 1986 toyota pickup SASed AHU tdi
I really hope it will all be done today. please.
PlaneCrazy
Province of Quebec, Canada
Gone...
I think today is just further (I believe written) submissions, not a hearing. It would surprise me if the judge rules today after receiving the submissions. He will want to examine them first which may take a few days. Would it be too optimistic to shoot for a week from now? Knowing how slow the Canadian court system is...
n1d0n
canada
Yes this is probably what will happen.. I was just hoping for something faster! :-/
mxs
Ontario
2010 Golf TDI
Well, you can think whatever you want, I just don't think this is in the cards (unless a vehicle you are talking about has an available fix the government signed-off). Your firearms example in my view is not a very good analogy, on contrary.
mxs
Ontario
2010 Golf TDI
Based on? ... Oh the FB page, eh? Yeah, and a cheque for full purchase price is on its way.
Seriously, the judge wanted to have the legal counsel summary of the hearing back to him by today! .... so he can do some reading, thinking, calling Quebec, calling EPA ..... whatever ... in the next several weeks. Then, he will call them back in and tell them how he sees it.
n1d0n
canada
what are you angry at??? It was just a comment I made stating that I would really be happy if it would all be done today.. I don't do facebook.
uchu
Markham ON
I think it's fair to say that we all wish that a ruling were given today and that the settlement program would roll out before the end of the month. Is it likely to happen? Unfortunately, no. There are quite a few loose ends that need to be finalised before a final ruling can be given. And, like I said before, the outcome is not going to please each and everyone of us affected TDI owners.
Regarding the judge meeting with counsels from both sides, I think that the purpose was to receive a summary with information that would answer his main questions and/or concerns about the settlement as it was proposed. Let's hope that : (1) It actually happened or is happening today, and (2) the answers that he receives are good enough for him to clear a path to a ruling. The same goes for the ruling of the judge in Quebec.
GigaFire
Vancouver, Canada
2012 CW Golf
Yeah, no. I want an answer today. After waiting another week, after four months of delays, after a year of waiting to be told to wait until now, I'm done. I just want my damn answer so I can move on.
uchu
Markham ON
"Patience is the art of hoping". - Luc de Clapiers
Cheekee
Barrie, Ontario CANADA
NO MORE 2012 Jetta TDI >> F150
I'm picking up my Jetta replacement tomorrow .... parking the VW until buyback ..... I'm 200 kms from extended warranty running out ... just enough to drive it to the dealership a couple of times .... hopefully we'll be on the other side of this mess soon .... I'll never buy another VW ...
Cheers
