^^^and a different engine/cat/DPF configuration. I think the OP was asking about CKRA engine owners.
For all intents and purposes, I believe the DOC/DPF configuration for the CJAA and CBEA is almost exactly the same, if not exactly the same as the one attached to the CKRA. I think even the '09 DOC/DPF combo contains exactly the same cores as our CKRA, except the assembly has the cat permanently welded downstream of it. I think the physical differences with our exhaust system start downstream of the DOC/DPF with the SCR system.
That said, OP, from the few high-mileage reports I have read here on the forum, the CJAA and CBEA TDI owers are finding their DPFs are getting full enough of ash starting at about 250K miles to start considering replacement, IIRC. No CKRA Passats have reported having DPFs full of ash yet, and there are a number into the 100K+ mileage now, as mentioned earlier. So our CKRAs should be able to achieve at least 250K miles I would think, but most likely even longer before we require replacement. Since the CKRA has a smaller turbo with greater response and uses SCR instead of relatively larger amounts of EGR, it should produce even less soot over the lifetime of the vehicle compared to the CJAA and CBEA, thus requiring less regens and likely prolonging the life of the DPF even more.
When it does ash up, either take it off and have it cleaned for a couple hundred bucks or replace it. A brand new DPF from VW parts websites tends to run less than $1k. Last I saw was ~$875. Big whoop. In the grand scheme of things, that's not much for a major part that'll last well into the 200-300K mileage.
Folks worry too much about DPFs. They are not a major threat do diesel engines, and chances are the average diesel owner will
never have to think about it, drive around its operation, perform any service to it, etc while he or she owns the vehicle.
Enjoy your Passat, free of DPF worries!
TurboDieselPoint
