Diesel Particulate Filter 2013 PASSAT TDI
jhort
CALIFORNIA
Passat
Hello all. Recently check engine light came on . Ran scan with dss and got a DPF code ..I cant rememebr, 8061 i believe. My question , does this mean buy new one or is there a way to perform maintenance on these? Ideas, suggestions, experiences , comments appreciated. Thanks
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
No maintenance on DPF once they are clogged or full. Some have had them cut open and cleaned, but they are fragile inside and usually break before filling. Really need the codes it set to tell anything.
jhort
CALIFORNIA
Passat
Thanks. The soot and ash levels per dss scanner are very low. I cleared the check engine and has not come on anymore. Just did an oil change per "service due now" . Noticed oil leak in injector wells and around valve cover torx screws. Gone start another thread for that . Will keep an eye on the DPF.
jhort
CALIFORNIA
Passat
So, check eng light came back on and same deal with diesel particulate filter. Below are codes taken from VCDSS:
Address 01: Engine Labels: 03L-906-022-CFC.clb
Control Module Part Number: 03L 997 009 J HW: 03L 907 309 S
Component and/or Version: R4 2.0l TDI H23 9982
Software Coding: 001D0012042400000000
Work Shop Code: WSC 22194 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005 (VW41)
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B233CC303E5FA321A9-806E
1 Fault Found:
8863 - Diesel Particulate Filter
P2459 00 [237] - Regeneration Frequency
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 212169 km
Date: 2122.14.27
Time: 09:53:54
Engine RPM: 1310.50 /min
Normed load value: 0.0 %
Vehicle speed: 70 km/h
Coolant temperature: 81 °C
Intake air temperature: 32 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.180 V
Unlearning counter according OBD: 40
Exhaust gas jet volume in particle filter: 85.6 m³/h
Particle filter: difference pressure: 84 hPa
Particle filter: soot mass measured: 22.37 g
Particle filter: soot mass calculated: 22.36 g
Particle filter: differential pressure: dynamic offset: -26 hPa
Exhaust gas temperature sensor 3: 261.1 °C
Exhaust gas temperature sensor 4: 214.2 °C
Readiness: 1 1 0 0 0 End
I still have oil leaking out the back of valve cover and will be replacing it.
Any ideas, suggestions, experiences with the DPF code greatly appreciated. From what i gather , this things supposed to auto re-generate to keep themselves clean, but that is not happening..? Mileage is at 131,500. Thanks again.
Check the exhaust pressure sensor, and its connections. There could be a leak or a blockage in the tube/hose. That's what the ECU uses to determine DPF status.
jhort
CALIFORNIA
Passat
Thanks for suggestion. Found a video mentions replacing that sensor but for diiferent fault code. I see the sensor is located behind valve cover, where some of this oil that is leaking out the rear of cover may be falling . Could it be possible the oil on the sensor is causing this fault?
Tom in PT
Twilight Zone, WA State
I think Oilhammer is referring to a different sensor, its right under the engine cover, up high, passenger side, two tubes coming out of it. Blow out those tubes first. I had an obstruction in one a few years ago. Do some searching here for the P2459 code - some threads on that common fault. You may need to replace that sensor, which is what I did.
danmin
DFW
2014 Passat 2.0 TDI @ 180k
I just deleted my 2014 passat. I have every connector and sensor and tube and clamp you could need. I’ll even sell you the full system if you want. PM me.
jhort
CALIFORNIA
Passat
Well new sensor did not help. Did force regen and no help either. I reset code and after about 40 miles engine light back on again. So, regeneration frequency means it's regenerating too frequently? I'm not sure what to do next. Ideas, suggestions, experience?
jhort
CALIFORNIA
Passat
Ok. Reading other posts I guess with new sensor there's an adaptation needed. How do I go about I t doing that with vcds?
danmin
DFW
I’d consider deleting the car if your area allows.
jhort
CALIFORNIA
Passat
Lol...spoke too soon. Engine light back on at 120 miles. Somethings happened though that it lasted more miles before coming on.
Jennesitah
WPB
2013 Passat TDi SE
Do you have VAG DPF to monitor the regens?
A while back I had issues with the DPF where it wouldn’t regen at all….
jhort
CALIFORNIA
Passat
Blew air thru hoses. Pur back old dpf sensor. Gave me 250 miles before engine light came back on. So, there are two of these sensors in system??
740GLE
NH
yup one pre and one post, both compare system pressure to ambient to get the delta across the DPF to verify how sooted up it is and possibly force a regen inside the mileage threshold.
jhort
CALIFORNIA
Passat
Geez. Had not realized that. So, the one I been replacing, one up top, may be good, and the other one , have no idea where it's at yet, may be the one needing replacement.
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
On the 2012-2014 Passat, one of the sensor is next to the coolant bottle and the other is between the DPF and the Engine.
jhort
CALIFORNIA
Passat
Thanks. I have been replacing the one by coolant bottle. I will locate other one this weekend. So when performing the adaptation process with vcds after replacing sensor , do we specify on vcds which sensor we replaced , or whichever one is replaced is automatically the one to to be adapted when doing adaptation process?
