S
SkyPup
Guest
75% of all diesel engine wear occurs at start-up, and 75% of that is where the most friction occurs -> in the rings and cylinder liners.
The limiting factor on the life a diesel engine is the cylinder bore, once the bore is shot, a rebuild is on order.
Wear can occur on any of the surfaces in relative motion, ie. piston bearing sufaces, bore, rings, grooves, vavle train, main and big eng bearins, as well as camshaft bearings. However, the most important wear that determines how long the engine can be run between overhauls is mainly that of the bore at the upper limit of the top ring travel, the radial wear of the top ring with resultatn increase of ring gap and consequent blowby, and the increase of side clearance of the top ring due to ring and groove wear. This wear is due to abrasion by engine deposits or by foreign matter that enters through the air intake or crankcase breathers. Abrasion by engine deposits usually increases with an increase in the severity of operating conditions, however that due to adventitious matter is usually indepent of operating conditions.
Provided that air filtration is satisfactory, the MAIN CAUSE of cylinder bore or linear wear is the corrosive action of inorganic acids derived from SULPHUR IN THE FUEL.
The MAIN PROBLEMS that arise in the lubrication of diesel engines come from the deposits arising from the combustion of the fuel and the lubricating oil, and from the partial oxidation of the lubricating oil.
The quality of lubricating diesel oils has increased exponentially over the last twenty or so years, while the quality of diesel fuel has dropped like a rock.
The deposits on the piston crown are derived mainly from the fuel with a contribution from lubricating oil additives other than ashless additives. Top land deposits are both from the fuel and the oil.
The BEST thing you can do for your TDI is to use high quality diesel fuel with the lowest possible sulfur content, lowest possible aromatic content, and a minimum cetane value of 50 to keep combustion deposits minimized. In addition, a high quality full synthetic oil with ashless additives can help with keep the rings free from deposit packing if the ring groove temperatures are excessive, ie above 250*C. Stationary diesel engines and marine diesel engines operating at constant loads for long periods of time have ring temperatures not exceeding 220*C and under these conditions ring-groove deposits are NOT a problem.
Get some top notch engine oil and use only top notch diesel fuel if you want the best for your TDI engine!
Remember, the fuel quality is even more important that the oil quality.
