Thunderstruck
thanks, I didn't read the whole thread-someone had bookmarked DBW's post as a single page like you did, so I didn't see the whole thing.
I have been looking for this info as I have seen many people talking about DB's break-in procedure. It looks like great information and I plan to follow it to a T as my TDI is supposed to arrive this week.Drivbiwire
Zehntes Jahr der Veteran Registered Vendor
Re: Break-in Period
Rules that apply for the life of the car
-When the engine is cold (below the first 3 white marks at the base of the temp gage) rev the engine to at least 2,500 rpms.
-When the engine is warmed up (above the first three white marks) Rev the engine to no less than 3,000 rpms.
The reason for this is to keep the turbo on boost, clear the VNT guide vanes and apply firm pressure to the rings for optimal sealing against blow-by gasses. The rings need the boost to seal since its a turbo charged engine, babying the engine is detrimental and will lead to issues with compression if done so for very long.
First 1,000 miles
Keep rpms below 3,800. Avoid steady rpms. Frequent firm application of power is strongly recomended up to 3,800 rpm. Avoid the use of cruise control so that you naturally fluctuate the power with your foot.
1,000-5,000 miles
Use the full 5,100 rpm power range. Avoid steady rpms. Avoid the use of cruise control. Frequent application of full throttle is recomended to help seat the rings. City driving is ideal for breaking in a TDI due to frequent stops and acceleration. Once you get to 5,000 miles change the oil and perform your first service per the manual
5,000-10,000 miles
Use of the cruise control is ok at this point since most of the initial break in has occured. Continue to use occasional full throttle accelerations to continue to seat the rings. You will notice the engine become slightly louder during this phase due to less friction from the engine breaking in (normal for a diesel to become louder under lighter loads). If your going on a long drive and you are using the cruise, every so often step on the peddle to accelerate up about 20 mph then coast back down to your preset speed.
10,000-60,000
This is when the rest of the break in occurs. The engine from the factory will check out with about 475psi of compression pressure out of the crate. It will take at least 60,000 miles to reach the peak pressure of 550psi. For the most part once you get to 10,000 miles your compression will be around 510psi meaning that most of the break in has occured.
60,000-the life of the motor
The engines I have seen so far using a 5w40 oil are maintaining 550 psi of compression pressure with over 200,000 miles on the odometer. The owners have followed the advice above and do not have any oil consumption issues. This also means that with the higher pressure the engine is more efficient returning optimal fuel economy and reduced smoke output.
DB
Awesome. Thanks for the response.Lightflyer1 said:While driving. Parked there is no load on the engine and it does very little.
Life of the car. The turbo uses a special seal to hold the oil back that needs the turbo to be under some boost to work. You don't have to cruise around at 4k rpms though.
Should I do the above once at the beginning of a trip or how often do I need to reapply the revving?-When the engine is cold (below the first 3 white marks at the base of the temp gage) rev the engine to at least 2,500 rpms.
Would you say it's better to leave it in Sport mode then, for the break-in? Because in Drive it shifts at just above 2000. (Tiptronic is not an option for me, keep forgetting to shift)Keep rpms below 3,800. Avoid steady rpms. Frequent firm application of power is strongly recomended up to 3,800 rpm.
I don't see why not millions of vehicles have been broken in that way and there is no proof that DBW's break in procedures makes anything last any longer than a engine that has had any other break in procedures.BlueMotion said:Why don't people stick to the break in instructions from Volkswagen?
The break-in is just as much about seating rings as it is developing driving habits that lend to greater engine life and less chance of clogging and turbo damage than anything else.barshnik said:Thanks anyway, but I am using the very short procedure published in the owners manual for my '09 JSW TDI. Difficult for me to believe that the rings will NEVER seat properly unless you drive like a madman, or that the turbo will leak if you don't either.
No offense to DBW or anyone else, but I kind of put this info in the category of an 'urban myth'.
John F
John F
I myself have been reading a lot of the information posted here and have learned a lot. My one question thou is when i get my 09' TDI should i just take it on the highway and run it between 2500-3500 RPM for the first 350 or so KM or should i be doing city driving?40X40 said:Of course you do. You are a newbie. No offense taken or intended. Stick around and learn something, as we all have. Even DBW has learned a lot in his 13 years of TDIclub participation. BTW the rings will eventually seat, but why not have them seat in a reasonable amount of time?
Bill
Those are SHIFT POINTS not rpms to keep the engine at.Dark-Warden said:I myself have been reading a lot of the information posted here and have learned a lot. My one question thou is when i get my 09' TDI should i just take it on the highway and run it between 2500-3500 RPM for the first 350 or so KM or should i be doing city driving?
Oh, I've already learned a lot, and do intend on sticking around to hopefully learn much more. Yes, this is my first diesel car, but I've spent a good bit of time in my 60 years around engines of all types, including diesels.40X40 said:Of course you do. You are a newbie. No offense taken or intended. Stick around and learn something, as we all have. Even DBW has learned a lot in his 13 years of TDIclub participation. BTW the rings will eventually seat, but why not have them seat in a reasonable amount of time?
Bill
__. Yeah, John, lots of good info from good people on this site. I didn't break my engine in according to DBW's rules (I was too easy on the engine) and it took a longer time for my fuel econ to come up (see my earlier post). I wish that I'd done compression tests but I'm pretty sure that the compression was slower to come up, too.barshnik said:(snip) So, I guess I could have avoided the flaming by saying it was because of DBW's article instead of my normal driving habits, within the few limits in the user manual regarding break-in.
John F
Yesterday, at the ON GTG in Missouri, someone was talking about a TDI which quite possibly had never been revved above 1500 rpm (perhaps the storyteller was Frank aka Franko6). At any rate, this horror story included terrible performance, terrible fuel mileage, a clogged intake, and ended with a blown turbo, runaway engine, bent rods, and a gigantic repair bill. Babying a TDI engine is never a good idea.Drivbiwire said:The break-in is just as much about seating rings as it is developing driving habits that lend to greater engine life and less chance of clogging and turbo damage than anything else.
Sound's like an urban myth to me.TornadoRed said:Yesterday, someone was talking about a TDI which quite possibly had never been revved above 1500 rpm. At any rate, this horror story included terrible performance, terrible fuel mileage, a clogged intake, and ended with a blown turbo, runaway engine, bent rods, and a gigantic repair bill. Babying a TDI engine is never a good idea.
Maybe -- it does sound unbelievable that someone would short-shift at such a low rpm, consistently over many years. But if someone did, then an unfortunate outcome certainly seems plausible.BlueMotion said:Sound's like an urban myth to me.
the PD anti-shudder valve is electronically actuated. from hearing the clicking under the hood, it sounds like it re-opens much sooner than 5 seconds. maybe 2-3. ???Drivbiwire said:It re-opens 5 seconds after crank rotation completely stops.
Vacuum to hold the valve closed after the engine comes to a stop is provided by the vacuum reservoir mounted on the engine (black ball) near the oil filter housing.
DB
DB
I don't consider 1500 RPM short shifting. I do most of my mileage between 800 and 1300 RPM. I've worked on these motors for more than 20 years and have never heard of over boost due to RPM. Overboost happens due to too much load pedal at low RPM, but driving soft at low RPM is not going to damage the turbo. Set your scangauge to map the boost and you will see. To be honest I've never read as much BS in my whole life as I've read in this thread regarding break in proceedures.TornadoRed said:Maybe -- it does sound unbelievable that someone would short-shift at such a low rpm, consistently over many years. But if someone did, then an unfortunate outcome certainly seems plausible.
You live in Spain and burn what kind of diesel fuel in regards to sulfur, US up until a year ago had 500ppm sulfur levels which greatly increased soot formation and intake clogging.BlueMotion said:I don't consider 1500 RPM short shifting. I do most of my mileage between 800 and 1300 RPM.
Overboost is due to excessive soot formation in the VNT control ring. The ring binds up and stops moving. This reduces or prohibits the VNT from cycling to the low boost position. When the ring binds up and the car is accelerating, the VNT is initially set to high boost/flow. As the engines exhaust gas flow/energy rises and "specified" boost pressure requirements are met the VNT is commanded to cycle toward the low boost position.I've worked on these motors for more than 20 years and have never heard of over boost due to RPM. Overboost happens due to too much load pedal at low RPM, but driving soft at low RPM is not going to damage the turbo.
Frankly I am far from impressed in fact astounded you have such a lack of experience or understanding of these cars. You claim to have 20 years of experience yet demonstrate a complete lack of understanding in how these engines work by virtue of this single post.Set your scangauge to map the boost and you will see. To be honest I've never read as much BS in my whole life as I've read in this thread regarding break in proceedures.
You yanks make me laugh. Do you really think Volkswagen would really make a completely unique car for such an insignificant market.Drivbiwire said:Does your car have US Tier II Bin 10 emissions requiring nearly 100% EGR duty rates and retarded injection timing which increases soot formation?
Quite frankly your car(s) have nothing in common due to the significant differences in ECU programming and emissions strategies that are employed aside from using the same block and turbo.
I'd tend to agree although wouldn't call it BS. Your just as unlikely to do any harm following those procedures as you are to not follow them. I've seen tdi's go 300,000 miles with little more than recommended maintenance which were not broken in per DBW recomendations, and I had my 04 blow a turbo at 12,000 miles with usage similar to DBW.BlueMotion said:To be honest I've never read as much BS in my whole life as I've read in this thread regarding break in proceedures.
Fact is they do and continue to do so.BlueMotion said:You yanks make me laugh. Do you really think Volkswagen would really make a completely unique car for such an insignificant market.
Actually they make several engines for the US market. Ah, that wonderful 5 cylinder 170hp gas engine as STANDARD in the current US-spec Jetta/Rabbit for one.BlueMotion said:You yanks make me laugh. Do you really think Volkswagen would really make a completely unique car for such an insignificant market.
That's a gasser. I'm talking about diesels. Do US diesel car sales even form 1% of world diesel car sales?oilhammer said:that wonderful 5 cylinder 170hp gas engine as STANDARD in the current US-spec Jetta/Rabbit for one.
The 1V ECOdiesel was a US-only diesel engine. The setup on the early 1Z with its OBD-D was also US-only.BlueMotion said:That's a gasser. I'm talking about diesels. Do US diesel car sales even form 1% of world diesel car sales?
