ghostrider I
Right,
2012 A3 TDi Avant (sportback) with about 83K on the clock. Battery discharged, and I used my booster to start it. After it started and ran, the following yellow icons showed up: Brake, bulb failure, fuel low, etc. They are preceded by a beep. After that, there are messages displaying things like dipped bulb failure, turn signal failure, etc.
The signals flash faster than normal, a headlight is burned out. I find this hard to believe, because prior to boosting, no warning lights came on, and no bulbs were "blown."
What is the remedy?
What is the remedy?
