Okay, I going to post this here for lack of a better place to put it, but at 31 pages in, I don't know if it will ever get seen. Perhaps some admin can suggest a better place?
You may learn from my experience!
I have a 2003 with the 1.9l and about 315,000 miles on it. Regular oil change, yaddayaddayadda. At about 240k miles, it started not performing so crisply, and around 280k it started slowing on hills, and at about 295k one of the valves on cylinder 1 went pear shaped. A local German specialty shop rebuilt the head and off I went.
Shortly after the rebuild, my wife wanted to move the car. "The key's in it." She came back and said it wouldn't start. What? It has never not started. On a lark, I recalled that I had bought a replacement fuel filter because I did not remember ever having replaced it, so I reached down on the bottom of the fuel filter and drained a little (probably not the best idea) and it started right up. So I replaced the filter and then spent a week fighting the fuel leak and then finally replaced the thermostatic T and the leak went away. Suggestion #1: if you replace the fuel filter, buy the T at the same time. It doesn't cost very much. You may not need it, but how cheap do you want to be? Also, read up on purging the air out of the lines before you start
For a very short while after that, it seemed like some of the torque had returned, but it was not much and short lived, so I have been trying to decide what to do with it. Finally, I decided to see if there were some simple things I could do and started with these:
http://www.myturbodiesel.com/wiki/low-power-constant-tdi-engine-repair-and-solution/
http://www.tdiclub.com/TDIFAQ/TDiFAQ-8.html#e
I hooked up the VAG-COM USB thingie and started down the list. MAF sensor was good, check that off the list. Boost ... what the heck? There was absolutely so boost no matter how much boost was being requested. So after a quick glance around the vacuum hoses and the Bentley manual, 1 thing was clear (and it was not the manual): a hose was missing. I would have said 2 things were clear, but I think the Bentley has an error in it because the N75 diagram for the 1.9l is opposite the 1.9l PD.
I found the missing hose, hooked it up, and started the car. Immediately, it was noticeably smoother running at idle. The hose had a kink in it, so I suspect it is leaky. The order has already been made to McM-Carr per the OP. I then took it out for a spin, and here is where my troubles got ... interesting.
Right away, it was clear that some torque had returned and also that the brakes were working better. Duh - vacuum boost on both, right? So I got on the freeway. While shifting from 4 to 5, the engine just went straight to redline and didn't stop. I mean, I took my foot off the gas, and then turned the key off, and then turned it back to the ON position, and then turned it off, and then took the key out. Black smoke was pouring out the back, I'm doing about 50 on a merge lane on a bridge going over a river, nothing will stop the engine, and now the steering wheel is locked because I'm holding the key in my hand. Fortunately (or perhaps not so fortunately), I've been in similar situations, so I was more perplexed than frightened. The engine finally stopped (starved of fuel, I suspect), but the black smoke kept coming. I glanced at the fire extinguisher, turned on the E-flashers, got out and popped that vacuum hose back off, and went home without further incident.
My theory is that the vane actuator and/or the N75 had not been used in such a long time that gunk had built up on it/them, and it/they got stuck when I was accelerating onto the freeway and the car was requesting full boost for the first time in a year or more. When I got home, I put the hose back on, revved it to 3500, saw no more sticking, so I put the VAG-COM back on to log it if it happened again, and took it out for another spin. No problem the second time around, so ... we'll see. In any case, it ran much better, but I'm sure the full vacuum hose replacement will be a good move.
[UPDATE: Turns out that this may have more to do with oil built up in the intercooler plumbing. It still starts cold, so possibly no damage done. Suggestion #5: check the intercooler once in a while. See
http://www.tdiclub.com/TDIFAQ/TDiFAQ-7.html#f]
Suggestion #2: diagram your vacuum hoses prior to any major surgery. Replace them at around 240k miles. The Bentley manual is lacking in this regard and may have an error on the PD diagram (it shows the PD N75 gazinta and gazouta opposite to every other diagram I have seen, the placement of Ts is inconsistent, etc.).
Suggestion #3: baseline your MAF and boost performance with the VAG-COM logging function early in its life. Check it out regularly. Don't wait until you're just fed up with it. I never got a single DTC for this problem, so it appears to have been a combination of worn vacuum hoses and possibly carelessness during the head rebuild. The change was a mixture of gradual and correlated with other events, so it felt like the result of unavoidable wear and tear.
Suggestion #4: Start with TDIClub forums and work your way back to the dealer as a last resort.
