uzi_cupra
I changed my vacuum control module this morning -
But no luck what so ever.
Every pipe is holding pressure and vacuum except the 2 which come off for the old egr and anti-shudder valve as they are no longer in use (this was always the case and never been a problem).
Actuator holds plenty inHg vac and the rod moves down and releases fine when vacuum is released.
Fuel filter and air filter are fine and the intake is spotless.
The brakes feel fine and there is definitely no boost leaks from the turbo through to the intake - pressure tested this many times to check and they are fine.
The turbo is coming off to fit a new manifold so will bench test the actuator and ensure it is definitely not at fault.
I have disconnected the MAF sensor and this doesn’t make a difference (even though it is mapped out) and it just comes up with a fault.
I disconnected the MAP and it throws up a fault with the traction control light.
This really has been an annoyance - esp because i'm not doing the usual "newbie" thing and ask before doing the checks.
I surely can't be missing something?
