JoeBags
Thank you for putting a great guide together got me out of limp mode, slamming a full 90hp now ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Sounds to me like a leak in your fuel line on the suction side. allowing a steady flow of air bubbles in. Does your rubber fuel line look wet? it doesn't necessarily leak fuel, like i said i think it's the suction side so fuel wouldn't come out it would let air in, however when the engine is shut down it would seep out of the line and make it look wet.hello, I'm new to the forum, I have a tdi vw golf 1999 1.9 liter, manual transmission, love this car but recently got a scary sound from the engine, I heard a tap sound and smelled burning one morning. After that I got the following problems, engine starts slow, it takes a long crank time, 3 to 4 seconds in sacramento California area weather, after starting it, it runs smooth but has a knocking or rattle sound at the motor, this knocking sound increases as I put a load under the motor, the engine knocks at every speed, once in a while this knocking sound might go away for 2 seconds and come right back when i'm going down the highway, but it will only go away for this random 2 seconds at highway speeds, otherwise it's alway knocking or rattling. I saw some of the knocking sounds on youtube and their just a little louder than mine. Mine runs smooth, just the knocing noise and slow start up and slow acceleration. It used to be really quiet with lots of power, i got it smogged at a smog shop 2 weeks prior.
Every time i put it under a load, for example 1st gear, it will make this knocking rattle noise even more, especially if i put it in 1st gear partially let off the clutch with the break peddle pressed down, it aggitates the noise full blast (i did this just to diagnose where the noise is coming from). It sounds like an exhaust leak but the exhaust and motor mounts look good.
I checked the timing-it's dead on
I changed the fuel filter-no difference
I put in a new mass air flow sensor-still does it.
I opened the fuel lines just above the injectors while running the motor-plenty of diesel fuel comes out.
I took the cam cover off and ran the engine-it threw oil everywhere but i didn't see anything wrong in the cam shaft area.
While the engine is running in idle if i partially close the shutter valve where the engine shut off is (next to the egr) it will agitate the noise too. I can live with the slow start up and slow speed but the knocking sound is too serious to ignore. Sure would appreciate any help. Thank you
I have fixed this problem on many cars before however this time it has been a nightmare.
I changed a brake pipe from the master cylinder to abs pump.
The car was driven in and out of the workshop with the intake off and the pipe work from the intercooler however only to maneuvour the car. The car sat for a few days with the bits disconnected while I waited on the brake pipe.
Since fitting it the car has been going into limp with the CHARGE PRESSURE CONTROL: NEGATIVE DEVIATION code, if I restart the engine it will give me a little boost after 3500rpm.
I have gone through this entire thread and follows the troubleshooting advice but nothing seems to work.
I used vag com basic setting group 11 to see if the actuator is working, which it is. I do not have an n75 instead mine is the one with the vacuum control module which sits above one of the top mounts. I removed each vac line and connected a hose to each end, blew in and sucked on each to check for any leaks, but nothing.
I checked all intercooler/turbo pipework.
Checked brake booster pipe, brakes are fine too.
Rod length is fine, no sticky vanes,
Maf is mapped out,
Turbo wheel spins freely.
The car in question is seat Ibiza cupra tdi. Finished my build not too long ago and it was holding 2.2 bar no problem, was driving like a dream. If someone could help me out it would be great! Don't know what I'm missing.
Cheers guys.
One last thing, could the fuel filter be causing such an issue? It has not been changed for some time now..
have you checked your actuator rod length? you sure you have checked for split hoses?Seems to be an ongoing problem for these TDI's i have having the same issues,
http://www.audi-sport.net/vb/a3-s3-...er-4th-5th-gear-around-1800rpm-limp-mode.html
Yeh adjusted it took it for a run then re set it again.have you checked your actuator rod length? you sure you have checked for split hoses?
Anyone have any ideas what could be going wrong?I have fixed this problem on many cars before however this time it has been a nightmare.
Maf is mapped out,
Cheers guys.
Have you do any live data through vag-com or run a fault code whilst in limp mode?Anyone have any ideas what could be going wrong?
I am getting charge pressure control negative deviation.Have you do any live data through vag-com or run a fault code whilst in limp mode?
I should hopefully have mine today so will let you know what that said.
This is why I'm so confused, I haven't only retraced my steps once but on several occasions and everything is in tact. I am just about to change my fuel filter, and then re check all vacuum lines AGAIN with my vac pump..If it was caused by the brake work, you might be able to retrace your route to see what you could have mistakenly disconnected? Or boost tubes that you may not have completely connected? How do the brakes work now? Good response (ie, good vacuum?)
I would get a vac tester on your pump, it sounds like you have fixed the leak now the pump cant keep up.Ok spent the whole weekend trying to fix the car...
I pulled all my pipes off my Vacuum control module and pressure tested each one. Actuator holds more than enough vacuum, vacuum reservoir holds plenty vacuum too. the brake booster pipe was removed, stuck my thumb on one end and vacuum tested to ensure it was not leaking and this was absolutely fine too.
After putting everything back together it is still the same.
I do get boost but only after 3000 rpm, and I only get max 1.5 bar instead of 2.2.
When it does boost it chokes for a split second and boosts and chokes and boosts again. As though there is a shortage of fuel. I changed the fuel filter just last week.
Still coming up with negative deviation - im starting to think it could be my actual vacuum control module??
