jimmybones
hi freinds,
im a 2016 audi sq5 owner.
car has about 50k miles on it.
i had the dpf check manual waring in my display a few days ago....
then i did a drive 30-40 mins at about 2000 rpm.
warning wouldnt go away...
after that i startet the manual regeneration with vcds.
it took up to 40 mins then it canceled and aborted.....
now my dpf light is on and the car is in limp mode and wont go above 2500 rpm
with vcds i get this errors:
Thursday,12,November,2020,14:20:23:39370
VCDS Version: Release 18.9.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine Labels: 059-907-401-V2.CLB
Control Module Part Number: 8K5 907 589 C HW: 4G0 907 589 B
Component and/or Version: 3.0BTD EDC17 X23 0008
Software Coding: 2A2A4032257603030000
Work Shop Code: WSC 37270 002 1048576
ASAM Dataset: EV_ECM30BTD0118K5907589C 001010 (AU48)
ROD: EV_ECM30BTD0118K5907589C.rod
VCID: 41897CF4D01000429A-8014
2 Faults Found:
5188 - Diesel Particle Filter
P2463 00 [167] - Excessive Soot Accumulation
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 79930 km
Date: 2020.11.12
Time: 13:38:59
Engine speed: 993.50 /min
Normed load value: 36.1 %
Vehicle speed: 0 km/h
Coolant temperature: 81 °C
Intake air temperature: 20 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.340 V
Unlearning counter according OBD: 40
P Flt Ld fac Ash Cor: 0.9301
Particul.filter diff.pressure: 11 hPa
Exh t Adap T Oxi Cat Ds: 339.7 °C
Exh t Adap TP Flt Ds: 238.8 °C
Current operating mode_2-Bits 0-7: 0
Current operating mode_2-Bits 0-7: 142
5189 - Particulate Trap Bank 1
P2002 00 [039] - Efficiency Below Threshold
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 79930 km
Date: 2020.11.12
Time: 14:22:09
Engine speed: 2022.00 /min
Normed load value: 37.6 %
Coolant temperature: 88 °C
Intake air temperature: 26 °C
Voltage terminal 30: 12.920 V
Ambient temperature: 12.0 °C
Particle filter: offset for differential press.: 0 hPa
Particle filter: soot mass measured: 5.11 g
Particle filter: soot mass calculated: 24.42 g
Particle filter: kilometers since last regeneration: 658570 m
Particle filter field regeneration: cancel conditions-Bits 0-7: 1
Particle filter field regeneration: cancel conditions-Bits 0-7: 0
Readiness: 0 0 0 0 1
www.Ross-Tech.com
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 79930 km
Date: 2020.11.12
Time: 13:38:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 79930 km
Date: 2020.11.12
Time: 14:22:09
