mk3
I started doing some logging with VAG-USB interface and I think I may have found a better way to get my IQ adjusted for the PP520 nozzles. The standard way is to get the engine idling under nominal no-load and hammer mod or move the IQ adaptation value.
I have never changed the adaptation value and I was curious how the computer would respond. I decided to move adaptation down by 100 at the 1/2 way point on my commute.
What I found is that the G149 sensor for the quantity adjuster did not change at all before/after I mad a change of 100 to the IQ. This is not too surprising since I was driving the same car with the same load down the same freeway. The IQ increased by 2. This was true at idle as well as on the freeway.
I had made several logs during this week and it was very clear to me that this new log showed an offset in the values.
you can see it here
Furthermore, the IQ is reported as mg/str. I decided to try converting this to mpg.
I had to make one leap. It seems like the mg/str is actually mg/R. R being one revolution of the engine.
I would be awesome if someone can confirm or refute this assumption.
[EDIT - nope, it really is mg/str (mg fuel per stroke of the pump, 4 strokes per rev of the pump)]
I found a value for density of diesel fuel, and long story short, it showed 55mpg. That is probably not correct but it is way better than the 63mpg the car would have 'thought' it was doing before I changed the adaptation.
Here is a link to my calculations. I still need to fine-tune the rpm to speed but I know it is really close right now.
https://docs.google.com/spreadsheet/ccc?key=0ArHfnlbB1xu6dFhLeVhJaU9FelBHN2c0LVJrY3pEeWc
The 8mg/str that is reported at idle is very likely NOT the correct fuel consumption. Ideally I would have a way to map the IQ / Sensor reading over the entire range. I think it would help the drivability.
Next, I am going to do a similar test and monitor boost and the MAF sensor. I imaging that the engine computer is going to request different boost when I change the IQ.
I think this will be a better way to get the correct IQ reading - by logging values during typical driving conditions- calculating mpg from the IQ and RPM readings and checking them against actual mpg.
Any thoughts?
Does anyone have additional data that could feed into this? I'd love to have some data from a bone stock, well-running vehicle. I wish I had collected that before I did the nozzle change and hammer mod.
you can see it here
Any thoughts?
