Delete
Randomhomelesstdibeetlegu
Stinking onion land
00 ALH Tdi
Does anyone do this still? I need to do some logging AND tear apart the QA on my Bosch reman pump. I don't have vag-com and don't feel like screwing Uwe by using a hacked copy until I can afford a professional unit.
I could leave a cash deposit covering it etc.
My quantity adjuster has to come apart due to repeating p1561 and the VAG is required to hammer it back to where it should be even if marked (from what I read.)
TIA!
Mozambiquer
Versailles Missouri
TIA!
I've got some hex-com ones if you need. That and an rs232 to usb adaptor would be a good cheap way to get genuine vcds.
3L3M3NT
Sturgeon Bay, WI
04 Jetta GLS TDI, 04 RTDI
If I had seen this sooner, I could have "rented" my VCDS cable.
Let me know if you still need one.
NightHawk
Yankton, SD
I identify as a TDI owner
I saw a cable for sale. Looks like he bought the one with 3 uses, used it once and is selling his two uses…
But I thought the licensing is tied to his computer, so it wouldn’t even work on mine??
Am I wrong?
NightHawk
Yankton, SD
Okay, follow up question.
I am being told that there was recently a new engine installed, and after that installation the “cat says the computer is locked”
P2B
Toronto & Muskoka, Canada
VCDS VIN limit and ECU immobilizer are related like chalk and cheese 😳
VCDS cannot delete the immobilizer, if that's what you are trying to ask. You need a tuner for that.
NightHawk
Yankton, SD
That’s answers a huge question for me!!
about what vcds can actually do, which is weird because i thought i saw a video i watched where a guy disabled the immobilizer feature…
But this “computer locked” scenario, is that just a new ecu and then use vcds to program the vin into the computer?
burpod
teh stallionz!!1
cape cod, ma
computer locked - as in ecu bricked? if its bricked, you won't get the glow plug light to come on, and car won't start (it will crank tho). also, if that's the case, vcds will fail to connecto to engine module.
with mpps you can delete immobo from the ecu if you know what you're doing (easy once you know), as well as put in the right vin/odo on the ecu. not sure if vcds does that or not when you pair a new ecu to it.
kw1281test by @gmenounos with a cheap vag kkl cable can get the skc
