Delete planning assistance
Twitchytoes
United States
2014 NMS Passat TDI SE - 2.0L CKRA
I'm in the Midwest so I'm not sure how long it'll take. I'm hoping it won't be quite that long haha. I'd like to have halfway decent weather to do this delete in...
DodgeNerd
San Diego
2012 Jetta TDI. 2012 6.7 RAM 2014 ECOdiesel
How are you guys liking the Profidiesel kit?
looking to get the same kit for my Jetta cjaa, just got a CEL P2002.
Twitchytoes
United States
I have not yet received mine, but this could be due to my recent move. I'm currently in process of trying to figure out where the package is even at...
DodgeNerd
San Diego
I got some information from Darkside today that makes this a bit easier to tell what's going on. Definitely racking up the price now.... Can anyone attest to the difficulty or sound of a gutted DPF?
Not try hi-jack this post, but, in trying to wrap my head around this process, what are you guys doing for the egr low pressure innlet side?
after watching;
I have a better understanding of what needs to be done. So, the profidiesel kit doesnt seem to have a blanking option for the turbo low pres side?
The Darkside has a silicone cap, I assume its for capping the lp inlet side on the turbo?
BuzzKen has a Plug for EGR vacuum inlet, but i dont like the sound of that.
I guess welding a plate to the turbo would be best.
Twitchytoes
United States
after watching;
I have a separate EGR delete kit that I've purchased and I'm piecing together the remaining pieces to entirely remove the EGR cooler.
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
My plan for delete was to leave the egr cooler and just use a block off plate, but since my turbo went out. I am planning to remove it and the new turbo also have the high side egr deleted as well.
Now if I can get time to do it all :unsure:
nedyalkov
Toronto
2015 Passat
Hey guys,
I will be doing a delete myself soon as my nox sensor went and it costs 600 to buy.
My intent is to gut the dpf and leave the rest of the system untouched. I see there is a lot of comments about the EGR, but i had found a way to code with VCDS to whatever % you desire. Wouldn't that be enough to disable the EGR?
Twitchytoes
United States
Hey guys,
That does not work on the newer CRs.
DodgeNerd
San Diego
after thinking about it, i think ill do the same, cause there is no real issue leaving the cooler there right ? blank the lower that goes to the dpf, keeping the pipe that goes to the turbo, reroute the coolant ?
AverageAndy
Phoenix, AZ
2013 Passat TDI SEL, 2013 Jetta TDI 6MT
You don't even have to reroute the coolant, unless your EGR cooler is leaking or you want to take it out of the equation.
DodgeNerd
San Diego
its not leaking, but i think id rather by-pass it incase it wants to start leaking, cause coolant could get sucked into the turbo eventually if it were to fill up?
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
Yep that is all you need, a blank plate and a 3/4" barb hose fitting.
Twitchytoes
United States
@freewayross Any update on your end? I'm in a super odd situation since I moved in the meantime of waiting on arrival, so I'm in semi-panic mode. Just scanned the car and I'm now running nox cat efficiency and reductant metering module intermittent codes consistently again. I used to clear them and see how long they'd take, usually 6 months. Now it's less than one. DPF is at 60g ash mass out of 70g... My time is running out and I'm really hoping this pipe shows up soon.
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
I have 131k miles and projected to hit in 70g in about 167k miles.
freewayross
AZ
2010 Sportwagen TDI, 2012 Passat SE TDI
Hey haven't received anything yet, I'll let you know if it shows up.
d2freeman
NC
2013 Passat TDI SE
Where did the 70g number come from?
When I changed my DPF at 300k miles it had 98g and was still running fine, doing a regen every 200 miles.
AverageAndy
Phoenix, AZ
In VCDS under "Advanced Measuring" you can monitor soot load values (to see when a regen is coming up) and see the "Ash Load Limit," which in my car, also says 70gm as the limit. I took this to mean that DPF will be fully plugged up at that time and require replacement. You give me hope I may be wrong, and that my DPF could last longer.
Twitchytoes
United States
My dpf is regening roughly 200-250mi where it is currently. And yes, as above, the ash load limit per VCDS.
Twitchytoes
United States
Just a quick update: Still have not yet received the pipes from ProFi. Note to self, don't select economy shipping.... hah. I wish I had known it didn't have tracking. If anyone has recently ordered from there with eco shipping and received their order, lemme know how long it took.
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
I believe onced it shipped it took a week for me, it was UPS for mine and I had the UPS My Choice which anything shipping to me I get notified and had the tracking number.
turbobrick240
maine
Could be a long wait if it got hung up in Customs.
