Well never mind! The ac took 11 min. to come on this morning so I guess I just got ripped $380.00 for nothing..... When will this ever enddddd!Hope this is posting! Its my first time posting from my cell phone...
Just picked up the car from vw autoworks and they said there was a bad wire in the harness. They also had to replace the ac relay. They said that is why the ac never worked untill the car got warmed up. The fans would kick on when the car was warm and there for the ac would start getting cold. I hope this is going to fix it! Only time will tell.... I will know in the morning after the car sets over night. I will post when I get to work tomorrow.....
Lonnie
Dan,It is also interesting to note the difference between requested and actual fan speed. I have never noticed the difference to be that high before.
As you can see once you get to where you have full .820 amp control current requested, the compressor should start pumping right away, and it did not. This would seem to further indicate that the compressor's electrically driven Refrigerant Control Valve (RCV) is sticking - which is what I have thought on all the other delayed AC cars (A5's - not Passat's which have relay issues.) I also do not think the compressor is always loading fully even when it starts to work.
On yours, Pawel, I would suspect that the fans are not providing adequate cooling (though they are running), which is impacting the efficiency of the system.
I would also check the actual current being supplied to the RCV, Pawel.
Dan,On your vehicle, actual current is not reported to the ECM.
So I would put a clamp on DC ammeter and verify the current is what it should be. Once the current reaches .820 amps, that is all the control system can do.
I have reviewed your scan data.Dan,
I presume that in order to check the supplied current to the Refrigerant Control Valve (RCV), I should unplug the connector going to it and read out the current while the AC system is on?
And where is RCV located? I hope that I can access it from the top...
P.S. Dan, did you get my scan data?
Dan,Lonnie,
Please ask your dealer if you can have the compressor. I would love to get my hands on it.
Dan
Don,Hey Dan - Looks like I'm back in the mix. If you recall, about a year ago I had the same delay issue. This moved to the ac working intermittently. I originally replaced the pressure switch to no avail. Against my better judgment, I took it to the dealer to have diagnosed. They said it was the compressor and wanted $1200 to replace. I politely declined. I ordered a compressor replacement kit and had my mechanic install. He test drove and all worked well. When he got in again, it would not work at all. We suspected a bad compressor. After he talked at length with a tech that had great knowledge of these systems, I got the compressor replaced under warranty. The mechanic said the second replacement looked way better quality wise than the first. Well it has been a month since the second unit was installed. It had been working perfectly. Made a stop while on vacation. When I started the car again, no ac. Have not had it since. Working on my next move. May be a control unit issue. Perhaps it is sending constant current to the compressor instead of the pulse mode needed to operate and burning up the electronics. Too bad VW didn't stick to the technology that all other manufacturers have used for years. Makes for difficult diagnosis. I still have the original Sanden compressor. May tear down to see what makes it tick. Will be following this post to see what you all come up with.
never saw any resolution to this problem. having the same problem with 2006 jetta tdi. anybody have any luck with a solution?
Thanks for the advice, Not sure to whom this was directed but in my case the car is still under warranty, I want to know what the problem is to compare it to what the dealer says.I am just trying to help, maybe save you some time and money, so don't think I am out to get you. I have been reading the threads and, as complex as the Germans made the VW A/C operation, I just do not think self repair is the way to go. You need so much equipment to do the tests/repairs properly. Recovery equip., vacuum pump, nitrogen, leak detector, gauges, meters, books. What good does it do to have a set of gauges if you can not interpet the readings? For instance, the low side, (suction pressure), depends on quite a few things, high side pressure, evap. fan speed, evap entering air temp, refrigerant level, and in autos, engine rpm. An example would be with R134, if you have about 50 psig, (low side), then you have about a 55 deg. saturted evap temp., what this means is that if you have say 80 deg. air going into the evap, depending on evap. fan speed, you would have maybe 65 deg air coming out, and you will not be happy, as it will not cool, as you cannot cool the car with 65 deg. air on an 80 deg. day. These figures are approximates. If you insist on working on your A/C, then I would advise you to read alot of books, go to nite school, and remember you are dealing with high pressures, and could easily loose an eye or even worse. I went to nite school for 3 yrs. just for A/C. Sorry I cannot tell you what you want to hear. Just trying to help.
Alright, at some point one would expect common sense to kick in. So odviously just saying that the compressor is at fault is not enough, Say there was an internal valve on the compressor that is sticking, once the valve opens the AC could function as expected. This is not rocket science, I'm sorry, I do not mean to say that your 3 years of school or your experience is something anyone can do. I agreed with your previous post, and thanked you for it. but also understand than you are dealing with different technical levels, do not assume people don't know what they are talking about, I don't know what your comment on the Toyota was all about.Well, was meant for everybody. If someone says their compressor is the cause of delayed cooling, but it cools fine after delay, would someone please tell me technically how this is possible? High priced items mean more profit, the money is made in parts, not labor. A successful "hosing" means you do not know you have been "hosed", you cannot beat someone at their own game.
Working on a 92 Toy is not even close to a newer German car, how much diagnostic ability does it take on a leaking evap?
