December 2008 Mileage Thread
scooperhsd
Kansas City KS
This is a month by month competition. Every time you make an entry it will be added up and recorded together according to the fuel type and car/year you are driving.
THIS IS NOT an individual tank competition (or a partial tank competition for that matter).
Entries will be accepted until January 5th 2009, but remember, report tanks FILLED IN December.
Entry Format:
Driver:
Miles:
Gallons:
Model Year:
Model:
Tranny:
Fuel Type:
You are allowed to put more than one fill up in a post, so long as each fill up conforms to format.
MPG: (optional since I will calculate it automatically anyway)
(anything else you would like to add)
Hint on entering your data - after the colon ( ":") put a space.
US GALLONS AND MILES
TRANNY TYPES:
(x) A = x speed automatic
(x) M = x speed manual *
DSG = direct-shift gearbox
CVT = continuously variable transmission
* if you have swapped in a taller 5th gear please noted this (ie: 5M w/.681)
FUEL TYPES:
Bx = biodiesel - x is the percentage of bio
Biodiesel use equal to, or more than B20, will be indicated in GREEN.
ULSD / LSD / D2 = normal petroleum based diesel
Also please note if it's winterized
- please note if you are using a fuel additive (ie: ULSD +PS)
- - Power Service (PS); Stanadyne (ST); Redline (RL)
Posts not in format will not be tallied / corrected. If I have to do any editing to get your post in format (or to get the correct name), it will not be counted. Feel free to correct your own posts to get them in format.
Please do not go back and add additional fillups to a post. Multiple fillups per post is fine as long as all fillups are in format. If the driver name is not the same as your post name - this will be considered "Not in format" and will not be counted. Only exceptions would be "and spouse" etc.
DK
Massachusetts
2014 TDI Golf 6 speed
driver: DK
miles: 776.6
gallons: 15.062
year: 2002
model: Golf GLS
tranny: 5m
fuel: ULSD+2 cycle
mpg: 51.560 (probably winter blend now):confused:
cpm: 0.056 cents
Lug_Nut
Sterling, MA. USA
2015 GSW 6M in S trim the other oil burners: 1967 two stroke Sonett 1988 Bolens DGT1700
Driver: Lug_Nut
Miles: 606.7
Gallons: 15.287
Model Year: 2005
Model: B5.5V
Tranny: 5A
Fuel Type: B33
5 gallons of B100 and then filled with (probably winterized) ULSD.
scooperhsd
Kansas City KS
12/5
Driver: scooperhsd
Miles: 519.9
Gallons: 12.805
Model Year: 2000
Model: NB
Tranny: 4A
Fuel Type: ULSD
Tank MPG 40.6013
odometer 197745 miles
Bob_Fout
Oil Wanker
Indiana
Driver: Bob_Fout
Miles: 608.7
Gallons: 13.063
Model Year: 2003
Model: Jetta GLS
Tranny: 5M
Fuel Type: ULSD
MPG: 46.6
Lug_Nut
Sterling, MA. USA
Driver: BonJonBart
Miles: 695.5
Gallons: 17.953
Model Year: 1997
Model: B4V
Tranny: 5M
Fuel Type: B55
Taller snow tires are on now so longer "miles" mean fewer in number. Miles listed are odometer reading, and are not adjusted to compensate for taller tires.
jharrison
x
x
Driver: jharrison
Miles: 775.3
Gallons: 15.905
Model Year: 2005
Model: A4 Jetta GLS
Tranny: 5M
Fuel Type: ULSD
MPG: 48.745
Thought I would play to.
jazontyler
raleigh nc
2009 candy white 6spd sedan
first tank report
Driver:jazontyler
Miles:419
Gallons:13.12
Model Year:2009
Model:Jetta TDI
Tranny:6spd manual
Fuel Type:diesel
this is our first tank of gas in this car
she is not focusing on fuel economy (rpms a little higher). this is >90% around town driving (45mph & 35mph limits)
live in nc, temps are moderate, 30's to 50's now, most trips are also short, so car really never gets a chance to warm up much
computer says that the tank mileage was 29.6m/g, pretty accurate with epa estimates for city. expect it to improve with break in and warmer weather.
when it was on the highway, it was easily averaging mid 40s cruising at ~60.
Lug_Nut
Sterling, MA. USA
jazontyler said:
Driver:Myself and wife
Jayzon, the driver is identified by screen name.
Quick! Go back into your post, click on "edit" in the lower corner and change the driver to the screen name. Do this before your post is ignored for not following format outlined in post #1.
ScooterJim
Acworth, GA
09 Jetta Wagon
Driver: ScooterJim
Miles: 292
Gallons: 8.3
Model Year: 2009
Model: Jetta Sportwagen
Tranny: DSG
Fuel Type: ULSD+ADC+0.5 gal B100+ K&N air filter
MPG: 35.18 (Shell on the last fillup)
Cost: $2.349 (Chevron on this fillup)
Total mileage: 8486
Waiting to see if Chevron gets better mpg because of higher cetane rating. This tank was using Shell.
Local Atlanta commute 50h/50c, temperature 20-30F in morning, 40-50F afternoon
Waldek Walrus
Central Pennsylvania
2006 Beetle TDI
Winter is here...
Driver: Waldek Walrus
Miles: 599.0
Gallons: 12.198
Model Year: 2006
Model: NB
Tranny: 5M
Fuel Type: ULSD+PS
Mostly highway with a bit of local driving at the Pittsburgh end of the run at dead cold. Tire pressure knocked down so that it would be VW specified pressure at ambient (I did this in the "warm" garage so added 3 psi to make up for COLD). All runs in sub freezing weather, part of a run through snow and ice conditions. The ESP worked fine.
Tom71662
Florida
Jetta, 2006, Black
Driver: Tom71662
Miles:714
Gallons:14.039
Model year:2006
Model:Jetta
Tranny:5M
Fuel type:ULSD+PS
12/8/2008
Bob_Fout
Oil Wanker
Indiana
Driver: Bob_Fout
Miles: 549.8
Gallons: 12.278
Model Year: 2003
Model: Jetta GLS
Tranny: 5M
Fuel Type: ULSD
MPG: 44.8
Not even the *magical* (sarcasm from another thread) rolling hills of southern IL, KY and TN can help MPG this time.
Winter fuel, head and cross winds and fuel-thirsty hills.
Digital Corpus
Ontario, California
'97 B4 w/ 236K mi body, 46K mi soul
Driver: Me
Miles: 1000.1 (I drove around the station for the extra few miles and it's my first 1000mi tank!)
Gallons: 19.17
Model Year: 1997
Model: Passat
Tranny: Manual 5 spd
Fuel Type: ULSD/#2
TonyJetta
Tucson, Az
'15 Jetta TDI SE / '06 Jetta TDI DSG Pkg0 / '96 Passat TDI
Driver: Tonyjetta
Miles: 664.8
Gallons: 15.417
Model Year: 1996
Model: Passat
Tranny: 5sp
Fuel Type: #2 / ULSD
43.1mpg; 50/50 city fwy.
OSBOB
Ocean Springs, MS
2005 Passat
Driver: OSBOB
Miles: 0
Gallons: 1
Mdl Yr: 2005
Mdl: Passat
Trans: 5 Auto
Fuel Type: automotive diesel
fuel fill not operational so either 0 mpg or infinate mpg depending on your point of view.
Russellb05
Pittsburgh PA
2009 Jetta TDI
Driver: Russellb05
Miles: 365.7
Gallons: 12.230
Model Year: 2009
Model: Jetta TDI
Tranny: 6M
Fuel Type: ULSD
MPG 29.901
MPGGE: 26.313
First fill up.
Any Suggestion?
PaulXIII
Brookhaven, MS
Jetta, 2005, Reflex Silver
Fuel Economy
Driver: Paul XIII
Miles: 488.7
Gallons: 10.513
Model Year:2005
Model: Jetta Wagon
Tranny: 5 Speed Manual
Fuel Type: ULSD
MPG: 46.48
shegel
bonney lake
99.5 jetta 2015 Passat
Driver: shegel
Miles: 458.9
Gallons: 8.9
Model Year: 1999.5
Model: Jetta
Tranny: 5M
Fuel Type: ULSD
MPG: 51.56
MacBuckeye
North Carolina
2009 Jetta
Driver: MacBuckeye
Miles: 562.8
Gallons: 14.1
Model Year: 2009
Model: Jetta
Tranny: DSG 6 SPD
Fuel Type: ULSD
MPG 39.91
Miles on ODO = 4,596
don4sail
Pensacola, FL
2003 Golf GL TDI
December Mileage
Driver: don4sail
Mileage: 707
Model: 2003 Golf GL TDI
Tranny: 5 Spd Manual
Fuel: 12.4 Gal US ULSD
I have no idea why my milage slipped from the 60's down to 57 mpg despite finally getting into the 700 club, my best tank thus far. I did fill up at a different station , a different pump from the one I usually use, but the filling was the same (to the consternation of the people behind me); i.e. I wait for the foam to disperse and fill slowly to the filler neck as I have for countless times (Ventectomy in 2003). Also it has been cold for Florida,in the low 30s and the driving was all city, no road trips. I keep the tires at 45 Psi.
I'll try again.
scooperhsd
Kansas City KS
12/18
Driver: scooperhsd
Miles: 493.2
Gallons: 12.300
Model Year: 2000
Model: NB
Tranny: 4A
Fuel Type: ULSD
Tank MPG 40.0976
odometer 198238 miles
month to date miles 1013.1, gallons 25.105, MPG 40.3545
ScooterJim
Acworth, GA
09 Jetta Wagon
Driver: ScooterJim
Miles: 387
Gallons: 10.23 + 0.2B100=10.43
Model Year: 2009
Tranny: DSG
Fuel Type: ULSD(Chevron)+ADC+0.2 gal B100+ K&N air filter
MPG: 37.10 (Chevron)
Cost: $2.259 (Chevron)
Total mileage: 8874
Chevron 2 mpg better than Shell
Local Atlanta commute 50h/50c, temperature 25-30F in morning, 45-55F afternoon
PAW
galesburg, Illinois
2000 5 spd bug, 03 Jetta 5 spd con, 06 5 spd Jetta, 15 GSW DSG, 15 Golf DSG
Driver: Paw
Miles: 679
Gallons: 14.05
Model Year: 2000
Model: NB
Tranny: M5
Fuel Type: B2
Mpg: 48.33
70% country roads then the rest around town.
98fxd
Dayton, OH
09 JSW
12/2
Driver: 98fxd
Miles: 417.2
Gallons: 12.064
Model Year: 2009
Model: JSW
Tranny: 6M
Fuel Type: ULSD
12/12
Driver: 98fxd
Miles: 472.6
Gallons: 13.578
Model Year: 2009
Model: JSW
Tranny: 6M
Fuel Type: ULSD
Tom71662
Florida
Jetta, 2006, Black
Driver: Tom71662
Miles:623
Gallons:13.876
Model year:2006
Model:Jetta
Tranny:5M
Fuel type:ULSD+PS
12/15/2008 Snow, ice, slush
DK
Massachusetts
driver: DK
miles: 739.5
gallons: 14.004
year: 2002
model: Golf GLS
tranny: 5m
fuel: ULSD +3cycle +PS
mpg: 52.806
cpm: 0.0511 @ $2.699/gal.
Snows went on early in this tank. Weather was
fairly warm.
