Firstly, I want to apologize for the potential length of this post. I'm at wits end and in a back and forth with the dealer.
details: 2014 passat TDI with ~160k
My car went to MAG in Columbus OH on 16 JAN to replace an in tank fuel pump. i was adding oil fairly regularly so I wasn't surprised when they recommended a replacement of the valve cover gasket during their comp. inspection. i rolled off the lot after the weekend with a $2500 bill but also confidence in the repair decisions I had made.
Not 20 days and 1500 miles later i brought the car back because i was leaving oil deposits from a leak in the same vicinity. The dealer said the valve cover gasket was blown again and told me that i require a new engine due to excessive blowby caused by piston rings that require replacement. They are also not going to honor the warranty on the valve cover gasket because of the blowby.
they did not come to this conclusion by conducting a leak down check or checking compression. The service rep and technician told me that when they found it blown they contacted their engineers in Michigan and they told them to troubleshoot by leaving the oil cap on the fill port and essentially determine if there was or was not any blowby.
I came in to talk with the tech and rep and they told me that i need a new engine for sure. The tech said that the PCV/CCV is definitely not the culprit because if it were to fail the crankcase would instead vacuum. we talked about all of the possible diagnosis options and they wouldn't settle on anything but engine replacement.
No sooner than i return to work (an hour or so) i have an update to my service recommendation and it is for the replacement of the valve cover with the PCV which they apparently only replace as an assembly. their valve covers are $500 a piece but i would only be paying for parts as they would cover maintenance under the warranty.
i was very intrigued to find that on my service recommendations as they just told me that PCV is definitely not the problem. i called and was pretty much told they need their loaner back tomorrow (today) and that they would replace the valve cover/pcv but it would only be a 6-8 month fix, replace the engine, or just come get it and give them their loaner back.
i called today to have them honor the warranty and replace the valve cover gasket for the time (my intent being to replace the cover on my own dime for half the cost or less with certified vw parts). they said they will not honor the warranty because that will not fix the problem, but they will replace it under warranty if i purchase the valve cover through them and have them install it EVEN THOUGH they are saying that will not fix the problem either.
All in all i cannot say that my crank case pressure is causing that gasket to blow due to a huge lack in diag, but what i will say is that my dipstick remains sealed, there is no sut or smoke in my exhaust, and the car drives and idles just fine although i have to add oil regularly.
Any feedback is appreciated, I've been looking around for answers all over the forums but things are moving pretty fast and I'm awful at navigating through here haha. if you find this post and think it would better suit a different forum/thread please let me know!
thanks!
* update* brought it home and it looks like its pooling around cylinder 1. initial thoughts are that the valve cover is leaking at the rubber grommets around that injector, as those dont get replaced when you replace the VC gasket. i bought a certified vw VC from ECS tuning (great service had it next day) started tearing into it last night and identified that the #1 cyl fuel injector only had the copper gasket/washer on the end and not the oring. could that oring being missed cause that leak, the blowby, or my check engine light for cyl 1 tq differential (p1004) or a combination of them all?
thanks!
