CarolinaOwner
Hi Guys,
I am new and have the above problem with which to introduce myself. . I read a lot of postings before I decided on this topic but wasn't sure where to post it.
My girl friend and I bought a 2006 Jetta TDI from a friend about six months ago. The car was purchased new from a local dealer and always maintained at the dealer. I told her when we bought it that I did not expect to have time to work on it and we should always maintain it at the dealer... we agreed. I have enjoyed the car... just did a 2400 mile road trip to Minnesota..,turned over 170,000 miles in the process.
As soon as I got back, my girl friend took the car to the dealer for an oil change.
Shortly I got a phone call that the drain plug threads in the oil pan were stripped and they wanted to put in a helicoil. Then they said it wouldn't work and I needed to pay for a new oil pan to be installed.
I drove right over and spoke to the service advisor and looked at the car on their lift.
For 60 years I have worked on my own cars (except four times total and I regret two of those) and I have never stripped an oil pan drain. The car has had about 30 documented dealer oil changes and I told the service advisor that if they told new customers that the drain plug threads would only last for thirty cycles, no one would buy the car. I believe that if the oil change technicians had followed the factory manual torque specifications this would not have happened. What is your opinion?
Ol'Rattler posted just yesterday under Lubricants...
"As an aside, do not go to the quicky oil change places, it will not save you money in the long run. At some point they will probably over tighten your aluminum oil pan oil plug and expect you to pony up to replace the oil pan they FUBARed."
And that's why I sent my girl friend to the dealer, expecting higher standards of workmanship.
The service advisor told me that he (at my request) emailed VW corporation and they replied that the car was out of warranty.
I spent an hour on the phone today and was told by VW national that they would not do anything for us. That makes sense really since the dealer stripped it.
Any advice on how to get the dealer to help?
If I have to fix it myself, my best solution would be to drill out the hole, tap new threads (all under vacuum) and install a slightly larger plug with a new crush washer and never go back to the dealer!
Opinions and advice welcomed !
Thanks,
Richard in South Carolina
(my other car is a BMW motorcycle)
Thanks,
