tikal
Ok I realize that this topic comes up from time to time but instead of resurrecting an old thread I figure out I start a new one.
I do not need a battery right away but I figure out I will need one by the Fall since the current one will be three years old and might not do so well if we make a trip to the mountains and so forth. So out of curiosity I called a couple of dealers and I gave my VIN number and this is the battery they have (cost $154), three year free replacement):
I realize the reserve capacity is important (72 AH) but so is the cold cranking amps (CCA). For this specific VW battery I was told it is rated at 380 CCA. Really? I am not impressed.
Ok, so having said this I wanted to discuss the pros/cons of installing a size H7/94R AGM battery such as this one (found via https://www.battfinder.com/):
Ok, so regarding this AGM battery I have some specific questions/observations:
1) Could there be any potential damage to the alternator or other electronics of the Passat by using this AGM battery?
2) Would the charging pattern of the car's alternator damage/reduce life/performance (in someways) of the AGM battery? Is there any VCDS settings can be changed for an AGM battery?
In looking at this link from Deka Battery, on page 11 there is this table:
I have been monitoring the voltage of the new re-manufactured Bosch alternator installed on the car and the voltage range I have observed is 13.45 to 14.1 volts so it is unlikely it will overcharge the AGM battery but it might under-charge it in colder temperatures.
Other thoughts, inputs welcome.
000915105DGDSP - Vehicle Battery. AH, Amp, Hour - Genuine Volkswagen Part
Genuine Volkswagen Part # 000915105DGDSP - Vehicle Battery. AH, Amp, Hour. Fits A6, Beetle, Beetle Convertible, Golf, Golf R, S6
parts.vw.com
