BigVWman
- Joined
- Feb 16, 2007
- TDI
- A1 cabriolet tdi and 01 nb tdi and countless gassers!
Hell everyone, I have arrived at a point where i'm kinda stumped and open to suggestion. Some background: i bought a newbeetle tdi on here it, had a TB failure. The PO did me the "favor" of taking it apart to see the damage before i bought it. So i have never heard it run or verified its prior condition or cause of Tb failure(other than crappy belt). I bought a super low mileage great condition used head and of course belt n rollers kit(ina and dayco isoran). I am at the point where i start it and check timing with vcds and adjust. I could not get the injectors to flow fuel with the lines cracked so i started investigating, though i know it can take awhile, and found no power to stop solenoid with key on. I then start to panic thinking i have fried the ecu somehow. I look around in the car and find a stray 109 relay laying in the cup holder and a new one(very pristine) in the 109 spot. When i turn the ignition on initially i get glow plug light for maybe 1/2 second then it goes out. I can read ecu with vag com and get no errors. Initially when i first plugged in i had needle sensor intermittant open and intermittant glow plug fault, probably when i bumped starter to line up belt position in rollers per tech.Cleared them and they didn't come back. I have checked all the fuses with the ecu symbol on the diagram.
Sorry for being long winded but i have no bentley yet for this one and other than swapping ecu i'm stumped and i hope that isn't it! I'm not a newb i have been doing vw's and vw diesels(as a hobby) now 25yrs and have tackled some pretty rough ones. Usually with ease, but i need help!
