jadney
2015 TDI Golf Sportwagon
2.0 L turbo diesel, DSG tranny
~37,000 miles
Certified Pre-Owned from VW after DieselGate mods
We're on a trip and this morning, after a few thousand miles of trouble-free driving, I got this warning when I first started the engine:
Oil Sensor!
Service Vehicle
Above those words there's an image of an oil can with a squiggley line under it. This message appears for about 2 seconds after starting the car. This message is all white and is in the center rectangular section of the dash instruments. It turns out that I don't actually have to start the car to get this brief message; it comes on if I turn the car "on" and wait a couple seconds.
After this message disappears, there's a yellow triangle with an exclamation point inside it. That stays there as long as the dash is energized.
I do NOT get the yellow or red oil warning light.
I have checked the oil. It's full.
I've driven a few hundred more miles to where we're stopped for the night. The oil is still full, and the engine seems to be running perfectly fine.
I have removed the plastic engine cover to see if there's anything obvious that's wrong. I've looked for damage that might have been caused by rodents chewing on wiring. I don't see anything, but I don't know where the oil "sensor" is.
Where is the oil "sensor"?
Is there something more than the usual oil pressure switch?
I have tools and I'm a competent mechanic, just not familiar with this modern car/engine. So how much trouble is it to get to this switch/sensor to replace it?
My guess at this point is that this is just the usual oil pressure switch, which has gone open, so it's not shorted as it should be before the engine starts. Or there's a wiring problem. I'll be able to know better once someone gives me a hint on where to look.
thanks in advance for your input,
~37,000 miles
Oil Sensor!
Service Vehicle
