bhutchins
only codes thown are expected from "change" of equipment. I'll just have to wait for the tune
noone has really walked the path yet... so baby steps.. heck we been trying things out to see how far the GTB turbos can be pushed.. just not going WOT on our first try...You only planning on running 25 psi max? I thought someone said somewhere these engines are capable of 260hp (NOT wheel horsepower) and 35 psi...and stock-ish mpg figures.
Please correct me if I am wrong.
so far my logs are only up to 2601 mBar ie. 1.6 Bar boost (23.5 psi) / about 5 psi over factory with no problems, but have clamped connections to the aftermarket FMIC. the S3 cooler is probably a better choice. I know Storx has had the clips blow off the factory ICHow are those stock boost pipes holding up?
2601mbar sounds like it hits a diagnostic limit....so far my logs are only up to 2601 mBar ie. 1.6 Bar boost (23.5 psi) / about 5 psi over factory with no problems, but have clamped connections to the aftermarket FMIC. the S3 cooler is probably a better choice. I know Storx has had the clips blow off the factory IC
You are correct. Mark is trying to figure out how to modify this on the EDC172601mbar sounds like it hits a diagnostic limit....
Eventually I willAt least go for 2.0 bar + atmos next time.
original block so far.Hey Brian. Are you using the engine I sold you for this build?
If so, wow! Great progress!
Sweetness! Didn't know that the end caps matched up since it was for TSI/FSI, for $300 those things are cheap considering how much bigger they are.skip the FMIC, and get the european S3 IC with aluminum end caps, much larger. my FMIC only had about half the cooling volume of the S3
RyanP (darksidedevelopments.co.uk) who made my Turbo Kit, also has the euro IC for £250.00 (~$400USD)(the U.S. S3 IC has plastic end caps), and Ryan referances this guide http://www.vagfans.com/forum/viewtopic.php?f=4&t=290Sweetness! Didn't know that the end caps matched up since it was for TSI/FSI, for $300 those things are cheap considering how much bigger they are.
Now to find a DIY on changing out intercoolers. I'm taking my mods incrementally harder to ease my way into the more technical stuff...
