jj20_09
I have an 2011 Jetta sportwagen. Do not know if I am having an issue or not. The VCDS says everything is fine. No issues. Sometimes, especially when it is cold, it will seem to have a miss or hesitation. When you let your foot off the breakbyou will feel a kind of jerking. You press the gas and it goes away. You can bring the RPMs uo slightly and its fine. By slightly I mean just above idle. Sometimes it will run quite and after it a few seconds makes like the old school diesel knock sound. Got to looking at everything in the live stream data and found that in channel 146. Cylinder pressure adaption ground singal runtime for cylinder 1 is negative 7ms. Cylinder 2 and 4 are about 10.5ms and cylinder 3 is 14 5ms. I can see 3 being higher if it is making up for 1. Just do not know what it is taking about. Is that normal? Do I have a problem with clinder 1 injector? I have already swapped 1 and 2 glow plug since the sensor is in the glow plug and it stayed with cylinder 1. Does that mean I have an bad ground in the harness? Sorry for being ramdon. Just trying to figure out what this means. Any help would be awesome.
