What Nero Morg said -- I know there are definitely two brake switches, and I'm pretty sure there are also two on the clutch: one for the starter-interlock and a second one for disengaging the cruise control. Senior moment -- I don't remember for sure....
I believe it was on this forum that I found the link about how to install a new clutch switch without breaking it -- the link above is probably it. You'll have to remove the plastic panel below the instrument panel to see the switch(es), but that's not very involved.
One thing to keep in mind about that clutch switch: I was very surprised to find it's a normally-closed (NC) switch, but is HELD OPEN when the clutch pedal is in is NORMAL position, i.e., your foot is OFF it.
Now stop and think about that: what percent of the time is that switch blade being pulled back to keep it open (your foot OFF the clutch pedal) -- 90%, 99%, 99.9%? That's a bunch of stress on that switch blade, ALL THE TIME, essentially. No wonder mine broke. Seems like VW could have devised a different set-up, either a NO (normally OPEN) switch, or perhaps a photoelectric switch.
Maybe that's not the problem with your car, but I was flabbergasted to see the way mine --and probably yours-- was designed.
And BTW, as benmarks pointed out, mine is a 2005, but most definitely an A4 chassis, one of the last diesel (PD/BEW) engined-Jettas VW sold prior to the BRM common-rail engines. The (IMHO) rather un-attractctive 2005.5 model (the ones with the huge chrome "smile" on the front) was the last --and only a few at that-- of the Jettas to have the PD engine, before diesel sales were suspended so they could "perfect" the BRM engine.
Check that clutch switch!
