diesel_micah
2001 ALH TDI
My car has been swapped from automatic to 5 speed manual. Everything works, reverse lights, etc. except cruise control. When I check VCDS, the clutch and brake pedals and all cruise switches seem to indicate just fine in measuring block 06. However, there’s no cruise while driving.
VCDS soft coding is changed to 0002 for manual and Automatic TCU Is disconnected.
I can’t access CAN gateway as I have VCDS-LITE does this matter?
Possibly related, I noticed when the brake is applied I get a 17.0 in the rightmost measuring block 06 CCS field (seems odd)?
