I've got the Kerma CR190 kit installed and have finally been able to run it for about a month. I have a few issues to still deal with, such as a leaky intercooler pump, but overall I am very happy. It was a long road to getting it up and running, due to some unforeseen issues from previous owner's maintenance- fuel rail pressure drops. As part of the attempts to fix that (and kind of an excuse) the CP4 was replaced with a CP3 pump, both as insurance and to be ready for anything further.
I drove the car for a couple weeks on stock tune and while it was a nice highway cruiser, it definitely didn't feel as strong as the Mk6 2.5 I was leaving behind. However, a few months back I was able to drive the CR190 on a stock tune, and it didn't make much difference until above 3000, then I could feel it definitely was flowing more.
Now that the Kerma file is in and I've been able to drive it a bit, I have to say I really like it most of the time.
It holds. The power just does not stop, it's unreal. Reminds me of something out of fast and furious. Or a freight train.
I have to agree, the power really does keep increasing until above 4200 if you're willing to keep pushing the pedal down. Definitely like a freight train- it doesn't build the way I'm used power in a 2.0 TSI engine does, it takes a little bit to really start building. For typical highway driving, or in-town traffic driving, it's great and I'm happy that after all the pitfalls along the way it's working! Once you get the boost increasing, it just accelerates and accelerates, it can be freaky at times.
There are a few things I still need to investigate- during full-throttle acceleration runs, there's a weird flat spot in the powerband where it just feels like it's not adding fuel, both when in DSG and manual mode. Above 3500, I can feel the power begin to ramp up, but it's not really there until about 4000rpm. However, if I lift off the pedal as the transmission shifts and then add the pedal back in gradually, the power will build much more rapidly. If I get impatient and stomp on it, then the power fades again and it's a slow acceleration.
I had one day with the friend who put the muscle into this project to pull some logs, and we couldn't see any obvious signs- EGTs never got above 1150, intake charge temp stayed around 47C max, requested PSI is about 35-36 and delivered is generally above 32psi with no obvious fuel cuts like we saw when there was a leak from the fuel rail. Has anyone else ever seen anything like this- where if you lift and gradually add the pedal back in, it will allow much more power to be produced?
I want to check on this with Kerma, but I need to get that coolant pump fixed and practice collecting data before I bug them.
