cpinde
- Joined
- Sep 24, 2012
- Location
- Slower Lower Delaware
- TDI
- 05 VW Passat, 04 Jetta, 06 BRM Jetta, sold 15 Golf current
So I've figured out that my turbo is toast and as such it's time to upgrade. I'm fully deleted and am thinking I'll go with the xman CR190 hybrid mostly because it's water cooled and that should help me make heat in the winter, which is just about impossible now. Who else has used the XMAN CR190? How did you plumb in the water cooling? Any gotchas? What tuning did you go with? Did anyone do it without upgrading the HPFP, injectors, and higher fuel pressure regulator? Did you later upgrade the fueling?
