VCDS scan... guess I gotta order an O2 sensor as well... Already have the new antenna. Bought a new tandem pump since it's dripping. Also just bought a set of Eibach springs since the 1.8T ones I just installed ride too high (nice and stiff though).
Saturday,24,May,2014,13:19:45:05933
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: 3VWSR69MX4M108374 License Plate:
Mileage: 323770km-201181mi Repair Order: jetta
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWSR69MX4M108374 Mileage: 323770km/201181miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 997 016 L HW: 028 101 114 6
Component: RC s03g EDC G000SG 3791
Revision: 12345678 Serial number: VWZ7Z0D9320032
Coding: 0150031
Shop #: WSC 66565 257 00032
VCID: 275D019D95FA3926FAD-515E
2 Faults Found:
18628 - Oxygen (Lambda) Sensor B1 S1
P2196 - 000 - Signal too High (Rich)
Freeze Frame:
RPM: 2436 /min
Torque: 0.0 Nm
Speed: 112.0 km/h
(no units): 255.0
Temperature: 26.1�C
Absolute Pres.: 1060.8 mbar
Voltage: 1.898 V
Lambda: 12.9 %
16706 - Engine Speed Sensor (G28)
P0322 - 000 - No Signal - Intermittent
Freeze Frame:
RPM: 1953 /min
Torque: 0.0 Nm
Speed: 69.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101000
Idle Stabilization: 0.0�KW
RPM: 966 /min
Readiness: 0 1 0 0 1
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 3365E5CD51224586565-515E
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0003
Coding: 12340
Shop #: WSC 00066
VCID: 275D019DC5FA3926FAD-5124
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 00066
VCID: 2F6DE9BDED0A616632D-515E
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 906 Q
Component: KOMBI+WEGFAHRSP VDO V55
Coding: 15232
Shop #: WSC 00000
VCID: 3B75CDED29728DC68E5-5140
3VWSR69MX4M108374 VWZ7Z0D9320032
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: F0EFAAC1B0B4BE9EEB7-5140
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortger�t HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 377DD1DD155AA9A66AD-4B1C
Subsystem 1 - Part No: 1C1959801A
Component: 1H T�rsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802A
Component: 1H T�rsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811A
Component: 1H T�rsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812A
Component: 1H T�rsteuer.HR KLO 0202
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 G
Component: Radio 001 0016
Coding: 04031
Shop #: WSC 00066
VCID: 24471691B4CCD23EDFF-5140
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End ---------------------------------------------------------------------
