TonyJetta
- Joined
- Sep 15, 2005
- Location
- Tucson, Az
- TDI
- '15 Jetta TDI SE / '06 Jetta TDI DSG Pkg0 / '96 Passat TDI
Well, I think my B4 is another victim of the "D" shaped timing sprocket failure.
As some of you may have been following, I borrowed a set of PP520 injectors (and nozzles) from Abacus, to use while mine were sent out for balancing and install of Titan 502 nozzles.
It seemed no matter where I set the IQ, it would smoke. More so with lower IQ. But over the course of 500 miles, I would notice more smoke at times versus other times.
Monday, 6/17, I attempted to start the car for my commute into work. It seemed to be cranking fine, but wouldn't fire. I cycled the key and reattempted to start the engine. This time it fired and started. But not without a few puffs of gray smoke. I thought this was odd, considering the car was outside, and it was 70F at 5AM! Keep in mind I live in the AZ desert, where, for example, this weekend is forecasted to hit 111-112F!
At any rate, I quickly shut off the engine and have not restarted it.
I suspect, and a few others agree with me, that the crank pulley is moving and needs to be replaced.
So...parts I have on order:
Crank Yank - mostly because I don't want to fab my own tool - not the forecast above!
Timing belt kit - I have about 20k miles left on this one, so I figured if I do it while it's all apart, I should be fine for the next 60k!
Front seal & front cover gasket - I figure if I'm in there, I'll do it once, do it right, and be done!
If I think about it, I'll post a pic of the original timing pulley and crank snout for reference.
On a related note, I have been running the gates one-way clutch alternator pulley. I still think this is the way to go...I think the majority of damage was done over the 195K without the one-way pulley. Then, the extra power of the chip and then the nozzles.
Tony
Tony
