I did remove the fuel lines from the fuel filter. I have cracked the injectors and have fuel at all. There is a little air in the fuel lineIf an ALH pump can be pinned (in the right hole) it should be close enough.
Did you remove the fuel filter to get at the belt?
Loosen an injector line to see if you're getting fuel?
Sucker hole?Lock tools for the cam and injection pump?
Sucker hole for the IP?
Diesel need THREE things to run: air, heat and fuel AT THE RIGHT TIME.
Ok checked the link out and have just now put everything thing back to tdc cam shaft locking plate is in place injection pump locking pin is in place. If the cam shaft is locked means my air shut off valve is shut?What they are saying is did you lock your injection pump with the special tool or a drill bit? If you did not than your injection timing is off and the car will not start. It needs to be in a very small window to actually start the car.
http://www.myturbodiesel.com/wiki/a...acement-vw-jetta-tdi-golf-beetle-1998-2003-2/
Check this out, on the 10-15 picture is where you lock the cam. If you did lock the cam than your air shut off valve is shut when you are cranking and the engine isnot getting any air. But check this out first.
So what was the problem? Some folks here have tried to help you with very little information given so the least you could do is let people know what the resolution was.I got it started now I just need to find tune with vag-com which I don’t have
Evidently he tweaked the IP until he found a setting were it would start. Nothing confusing there..........So what was the problem? Some folks here have tried to help you with very little information given so the least you could do is let people know what the resolution was.
Yep. It's times like this I appreciate IATN where you get bugged to post the fix and if you don't, you start losing posting privileges. Of course there, you can only post one reply to your original help request which limits the conversation and is why I usually use the forums.I get an itchy feeling reading threads like this.
I apologize that I didn’t share the resolution. I took everything back apart and put it back to top dead center. Upon doing this I found that the injection pump was about 130° out of time. After placing that in true TDC and making sure nothing else came out of TDC I put it all back together crossed my fingers and cranked. It sputtered a little bit like it was Still a touch out of time So I advanced the pump and it fired right up. Again I apologize for not sharing what the solution was I am new to using forums And not to well-versed in all the proper etiquetteDon't you just love the explanation.
"I got what I want. You guys can go fish now..."
HOW ABOUT POSTING YOUR RESOLUTION??
Who da dog?Timing off.
Come to find out I had pinned in one of the false holes and later made a few more mistakes trying to achieve my goal. But in the end I realized. my thanks to the help from the wonderful people on here telling me to check timing again and make sure I wasn’t in false holes.Learn by your OR other's mistakes. Kind of the premise of just about all community forums. We SHARE so we can all LEARN, save others from added pain and expense.
130 degrees wasn't even close. Following procedures would never get you this far off.
