New here and need some guidance! 2000 vw jetta tdi 1.9 327k miles. No mods just regular maintenance and replacing worn parts here and there on this 20yr old girl!!
Driving home from work couple months back and I came around corner, got back on throttle and took off as usual. Went about 100 yards after turn and then died, I coasted a good way to be in a decent spot on side of road. Turned key off, popped hood everything seemed okay under the hood, timing belt in tact, nothing leaking so hopped back in cranked it over a few times and nothing. I towed it home and got home in dark. I Didn't tinker with it until the weekend trying to look online for a few common issues.
Things ive done so far:
-Primed injection pump, made sure air was out of lines and cracked injectors got fuel to shoot out. Cranked over and it seems like it wants to "fire off" but nothing. (crank no start)
-Ran codes with obd-2 tool and came across some bad glow plugs, replaced them and new harness.
-Replaced n75 valve
-Glow plug light would come on then go out as usual but still replaced relay 109.
-Battery went dead so its been on battery tender since I bled IP. I vcds scanned car and got online for some ideas. Battery tender got unplugged one day and forgot to get plugged back it so battery had gone completely dead. I had battery checked a week ago and it was bad. I replaced with new and been hooked up to tender ever since. The car seems to crank a lot better but still no bang...
I'd consider myself mechanically inclined but running low on ideas. Any help is greatly appreciated.
-Replaced n75 valve
