Hi, I'm brand new on this thread. I have a problem. I installed a replacement engine into the car. Typically cranks perfectly but doesn't start. I decided to prime the fuel by taking out the glow plugs. Turns out theres no puffs of diesel mist at all off any holes. I took off the fuel filter and put pieces of brake pipes on the hoses to bypass the filter. So I tested the fuel flow. I shoved one of the pipes into the bottle. There is fuel flowing from the inlet pipe the bottle filled up, then I connected that up to the other pipe that leads to the inlet part of the tandem pump. I disconnected the return pipe and theres fuel flowing from the return pipe too. The lift pump is making working sounds. This seems to me that the injectors arnt playing ball or would it be a tandem pump fault? I plugged in the vcds there are no DTC's whatso ever except radio. no warning lights when cranking. the engine is not getting fuel injected. What might be the problem? will I reset the injector rockers? the belt is new and the tools slot straight into the holes and tentioned bang on centre. crank and cam sensor is on and vcds would have picked up those problems otherwise. I haven't checked the fuel relay and not sure which one is it. I checked injector connector plugs nothing loose. the car doesnt seem to know there is a problem. any ideas?
