ok, so i bought this car that i prolly never should have(hind sights always 20/20)...its a 2003 jetta tdi, the coolant was filled with water only, i found this out when i got home. i live in colorado, also for some reason the heater core was bypassed (worry bout that later)...so i drained all the water out left lines open incase i missed some. now after have a few freezes, it won t start.. the compression in (1 and 2 hold fine at 450psi)cylinder 3 and 4 build to 450psi then it leaks off.. what do i do now, pull the head, could the block be cracked, blown head or head gasket, what should i expect..i dont see any freeze plugs. any help appreciated
