DieselRacer
banned
That is just the stock turbo which your car has already you want a cr170 turbo...
You know that feeling when you have a brand new CR170 turbo...and the car is all bolted back together, but you are waiting for your ECU to get back before you can start it... and the weekend is coming up?
Yeah, that feeling. Maybe Monday.
You can unplug and remove that sensor, won't throw a DTC. Just do your best to seal the connector up so water doesn't short it out. Same as the rest of them that are no longer used....There was a very small EGT sensor built into the LP EGR cooler.. for now that is still connected and tied out of the way. If I do anything else with the tune I'll figure out what sensor it is and have fault checking turned off...
Yes, it would be redundant to add yet another EGT sensor. The one in the turbine inlet can be found in group 99 using VCDS. Really though, once you have logged your tune and Malone has made any needed adjustments to keep the EGT limiter from being hit there is no need to monitor EGTs. Malone Stage 3 tuning keeps ECU's self protective EGT limit in place so that you cannot burn anything up. That said, if you really want to monitor EGTs you could use one of the DLC connected gauges like the one from P3Cars or even a Scan Gauge II using the "X Gauge" feature....How are you guys handling EGT readout? I'm running stock cat-back until I figure out which one I like and can afford, and it wouldn't be too difficult to stick a sensor in the HP EGR blockoff plate. But that's only cyl 1, and seems redundant when there are already FOUR EGT probes installed. I've seen mention of scangauge being configured to display one of the stock sensors.. your thoughts?
Where were you able to sell your stock parts? Ebay?Ha.. sucks to be you guys!
Kidding. I understand.
Either way.. I was able to sell my relatively low-mileage, stock tune DPF and turbo for within a few hundred dollars of paying for the CR170 turbo and intake. I had already bought the Rawtek down & mid pipes (with cat & resonator).. so the only other additional cost was the difference between stage 2 and 3 tunes. I asked about stage 2 with the CR170 turbo (to spare my clutch & IC piping, plan being to uncork it at a later date when supporting mods are in place) but no go.. so I ended up doing a tune on the mild side of Stage 3.
This thread is on point with regard to everything bolting up. Getting the DPF out was just as difficult as expected. Afterward, I unbolted the LP EGR cooler from the block, unbolted the cooling portion from the control portion (six T-25 torx screws), and slipped the two halves out between the axle & subframe. At that point getting to the manifold bolts was easy, and there was JUST enough room between the subframe/axle/oil pan to get the old turbo out and new turbo in. The heat shield on the exhaust manifold now only has 1 mounting bolt (as opposed to two) and needed slight trimming to clear the transmission-side extra stud on the CR170 manifold. I used a brass 90 degree 1" PEX elbow to bypass the EGR coolant hoses.. the hose running to the block was kept stock length, and I cut about 2.5" off the one running to the heater core. This hugged the brass elbow up against the other heater core hose, and was zip-tied beside it. There was a very small EGT sensor built into the LP EGR cooler.. for now that is still connected and tied out of the way. If I do anything else with the tune I'll figure out what sensor it is and have fault checking turned off.
Good tech, thanks....Yes, it would be redundant to add yet another EGT sensor.... That said, if you really want to monitor EGTs you could use one of the DLC connected gauges like the one from P3Cars or even a Scan Gauge II using the "X Gauge" feature....
Someone local. They apparently wanted spares, and mine were quite low mileage. I haven't looked at what used stuff is getting here in the classifieds, but I got about half of what they'd cost new.. which seems fair for lightly used parts. To be clear, I didn't get enough to almost pay for the turbo/tune/exhaust.. just the turbo.Where were you able to sell your stock parts? Ebay?
Every car I owned has been heavily modified. Yes it is key to keep all stock parts and put it back to stock when selling. I've always recovered about 60% of my modified costs when parting out. Of course my labor is worth nothing, but I do all my work myself.Keep in mind that modified cars usually don't command a price premium over stock. Most buyers don't want modified cars. You may be able to find an enthusiast who likes the mods and will pay for them, but it limits the potential buyers.
I think the emissions issue is a big one. My modified '02 will pass emissions in any state. A DPF deleted common rail car will not. So even if the buyer for your car is in a state where it will pass, he or she may be concerned about reselling it to a buyer in a state where it won't.
My .02 is that if you look at mods as an expense you won't recover, and if you protect yourself by keeping the stuff that will allow you to put the car back to stock, you're fine.
Have you noticed anything differently since the installGot the S3 IC installed yesterday. One step closer lol![]()
Lower EGT's on my P3 gauge. Seems normal driving is 100 deg less than before and under hard acceleration they climb slower and drop off quicker.Have you noticed anything differently since the install
I am curious about your fuel consumption in field 015 at full chat (ie. 4500 rpms) 3rd gear? Good data given in vaglogs of field 001, 008, and 011 too. (ie torque values in the mid to upper 400nm's in 008)One more flash today
We finally got the tune correct thanks to Mark Malone!!
Jeff,I am curious about your fuel consumption in field 015 at full chat (ie. 4500 rpms) 3rd gear? Good data given in vaglogs of field 001, 008, and 011 too. (ie torque values in the mid to upper 400nm's in 008)
My '09 RC3 is seeing 52 l/hr. and 1600degF too. I eliminated my pre-turbo egt sensor, and used the port for my isspro egt gage. I am running 70mg/R fueling with this turbo. I estimate 180hp/325ftlbs (my dsg will shudder at 350ftlbs). (I am straight piped of course)
I'll run 90mg/R when I get my big turbo installed, but don't know if injector can supply that like my pd150 race motor (250/375). I am hopping the bigger turbo should offer 225hp/350ftlb with oem injector/pump combo.
Jeff
That's awesome - that is my next project!!!!BuzzKen said:Just drove to Florida with my cr170, S3 intercooler. IAT's never went more than 10 degrees celsius over ambient temps in any situation.
That's the kit that I used, it had every nut, bolt, gasket & O-Ring that you will need. Highly Recommend as there is NOTHING worst than getting into a project and realize you are missing something.We have a complete installation kit that comes with the CR170 turbo we sell. It's not available on the site by itself, but if you give us a call we can get it to you. It includes all the gaskets Jon lists at the beginning of this thread and is $44.
Sweet so you guys carry the 170 turbo then? I ordered a 140 a while back but sent it back cause it ended up being the boost/intercooler tube was cracked. Thinking of one of the GTB Darkside kits too though. Itll be a couple months yet.We have a complete installation kit that comes with the CR170 turbo we sell. It's not available on the site by itself, but if you give us a call we can get it to you. It includes all the gaskets Jon lists at the beginning of this thread and is $44.
