Killabee228
Wow that is true. $1US right now is $1.26CAD
Which direction would you go? Seems likes there's a couple options for physically removing the butterfly valves. I wish the fuel rail wasn't part of the removal process.And it wouldn't be of use to me since I plan on removing the whole assembly anyway.
Yeah, I'm curious what he has to say. All he told me was that you have to request it but didn't comment on what effect it would have.
BuzzKen - do you think there is much difference from physically removing the flappers or just setting them open programmatically, I.e. tune them out and just leave the v157 in the open position all the time?
Great. I plan to have Malone tune it out so that level of intervention/effort works for me as far as the flappers go. Thanks .Just set in the open position.
mz1;4775870I am Malone Stage 2 and ...[/QUOTE said:Did you request Malone to disable the v157 motor [programmatically] when he did your ecu tune?
I don't recall doing that when ordering the tune, would you please explain why of the question and how would this affect my performance?Did you request Malone to disable the v157 motor [programmatically] when he did your ecu tune?
I have a cel with it unplugged and I am stage 2. No problems so far.I'm also wondering if the CEL comes on if the motor is unhooked on a tuned engine. I'd be willing to experiment if no one knows. As long as it doesn't go into limp mode.
Yes I did get fuel economy benefits indeed, I have done 4 complete fuel tanks with manual calculations and my mpg's went up 3-6 miles ( and by the way I am running 18" wheels, otherwise I think I could see even higher mpg's for sure)Later when you physically unplugged the v157, you got to the same result as programmatically disabling the flappers (they default open in the default motor position), and you are seeing at least an improvement in fuel economy.
Curious here.... are you seeing a CEL after unplugging the v157? I bet Stage 2 tune ignores all the CEL codes related to it.
I have no way of knowing, no VCDS here.Are there Error codes stored if you check with VCDS?
Intake flappers - look here, page 12Call me naive as I want to ask the following, we are talking "exhaust" flapper valve right? I have seen a couple of you refer to it as "intake" ??? I went to page one and pictures are disabled....just making sure I am not making a mistake...is there an intake flapper valve as well???....All this time I been talking about my exhaust flapper valve.
And to TDI Wagen: could it be that at least before Mike Malone was just disabling exhaust flapper on their program as std operating procedure assuming some of us would run straight pipes? there is a reason I was told my stage 2 program would support the delete....
