KERMA,
THANKS FOR THE INFORMATIVE STRAIGHT-FORWARD RESPONSE, GOOD INFO……I do have a couple of follow-on statements/questions with what you wrote if I may………..
OK, Didn’t understand within the ECU’s Software it synchs with the overall system specific to a vehicle’s VIN (assigned at the factory) therefore if everything doesn’t match, SHUT DOWN Occurs. Also, learned if an Immobilizer Delete tune is done it allows an unmatched ECU to be used. So-far-so-good…….. Is the Factory Assigned Immobilizer Data In an area on the ECU that can be written over or is it read only? Say In the case a body shop was doing a salvage rebuild where the ECU was damaged, could they take a used ECU pulled from another vehicle into an “Authorized VW Dealer” and they could re-burn the Factory Immobilizer info to match the vehicle’s VIN, or, must the ECU be purchased new from the factory.
ECU Adapts Over Time – OK, this needs a mind-meld, where is Spock when I need him. So with the stock software version I have running inside the matched VIN ECU, over time the performance could degrade to a point requiring a refresh to the software. I’ve read allot of people on-line saying they weren’t going to let VW touch their ECU ever again. With what you wrote they’ll have no choice down the line so in theory a Spare ECU with a frozen Software Version would become useless.
