I have upgraded it all. Bigger turbo the works just haven't been able to find injectors that aren't am arm and a leg. I'm rebuilding a cjaa for nitrous and a compound turbo set up so I'm looking to get the most fuel in as I can+1. Curious to see whats out there and if its worth the upgrade for injectors on these.
But have you upgraded to a CP3 pump yet with the 2200bar sensor?
Darksides are modified CUAA injectors. I bought them and sent them back. They don't fit very good and nozzle is not the right length.Buy once, cry once
Not sure if the CUAA piezos would work, but they flow an incredible amount from stock. Otherwise, pony up for Darkside's offering or reach out to S&S Diesel. Darkside almost certainly will include a duration map for theirs, which is critical for tuning.
The duration map they provide (at least for mine) has nowhere near the amount of data that EDC17C64 uses. It was enough to get us going though.I ended up sending mine to S&S and had them go 200% over on them. Not cheap with a duration map.
Im very curious about the head performing at 400hp/600ftlbs. Is there any video or like thread about this somewhere?Darksides are modified CUAA injectors. I bought them and sent them back. They don't fit very good and nozzle is not the right length.
Larger injectors are pretty much useless unless you go super high boost or port the head. With a single turbo the head maxes out around 260HP. Andre at S&S did prove a stock head will do 400hp/600ftlbs with compounds though.
I'm building a 450+HP CJAA right now and should have it on the dyno this summer. Ported head, big valves, Colt stage 2 cams ( requires head and piston machining for clearance), ARP 625 head studs, 200% over injectors, R90 CP3 and probably going to run it off Motec. I have a Holset HE200 4cm for a HP and then probably go with a Borg S366 or 369SXE for LP. My engine is in a Toyota Tacoma with a 5 speed but I'm working on a ZF 8HP adapter for it now that will go in along with the built engine.
All depends on how many test points you pay for. 100 points minimum is what I'm told and 10 per test point so $1,000 duration map. I think the EDC uses way more than that but again I'm going Motec from them so should be enough.The duration map they provide (at least for mine) has nowhere near the amount of data that EDC17C64 uses. It was enough to get us going though.
Sounds like an awesome build you have going there!
We're around 330bhp/440tq at the moment on my CUA, limited by charge temps (and resulting EGTs). The stock A2W cooler is just running away with temps after 4k RPM, and thinking an additional front mounted A2A cooler in the bumper is next step. Personal goal is 500tq, so we'll see.
There are a couple videos of it on S&S diesels Instagram. That power was only at 3500rpm. He never fully tuned or finished the project. Engine is for a RX7 drag car.Im very curious about the head performing at 400hp/600ftlbs. Is there any video or like thread about this somewhere?
I've reached out to s&s they sent me to darkside. I'm building mine fully and might upgraded my cp3 again mine off of the 6.7 cummins so it's not hard to hot swap the internals I want over 500 on just pump diesel. It will work great or blow up lmao either way. I'm also doing some prototypes as well. Full aluminum valve cover with ls ccv and a full aluminum swarl flate delete plate with a bigger intake manifold. I ported my heads more since I'm doing my fab work my self. So fingers crossedBuy once, cry once
I reached out to them to see if they are increased in a bigger injector build. I'm looking at getting cuaa injectors and honing them bigger honestly. I have a company willing to help me. Fingers crossed boysXman does offer a 20% over set for CJAA. Don’t know if it’s enough for your build though lol. Good luck!
made over 50 sets over the years, plug and play, no oil and fumes leaks , oem looks
i only work with new injectors, in stock
Try CP3 Upgrade & Turbo by MAC Performance on Facebook, he's usually very responsiveIs your website still your username? I'm receiving a 403 error when trying to visit the site
Not to completely derail this conversation but this is a high HP CR thread.. I have to ask. How is that GTE2260VZ treating you? Also what's your driving environment and how's the responsiveness? (high altitude/surge/lag)Try CP3 Upgrade & Turbo by MAC Performance on Facebook, he's usually very responsive
I keep looking at this turbo on Muchboost, I want it so badly lol. But my summer density altitude here is typically over 8K FT elevation, and I frequently drive to Colorado on I70 which takes me past 12K FT elevation.. so have to stay with something smallerHaha, it's pretty sweet I gotta say. Sounds like a supercharger with the anti-surge design. Comparing to previous GTD2265 and GTB2365, it moves more airmass at the same boost levels, and thus we have hit the MAF limit. So that is next upgrade, 90mm BiTDI MAF.
It's more responsive (credit to my tuner on that though), and better low end airflow aka drivability around town, though that comes with some surge potential that can be tuned out easily. Really really nice unit
Darksides stage 2 injectors are just modded CUAA injectors and will not be enough fuel for 500HP. My 200% S&S's should though because that's my goal also is 500+ fuel only. I have Colt stage 2 cams and associated machine work to make them work though because they are not drop in. Not sure you will make it there on stock cams.I've reached out to s&s they sent me to darkside. I'm building mine fully and might upgraded my cp3 again mine off of the 6.7 cummins so it's not hard to hot swap the internals I want over 500 on just pump diesel. It will work great or blow up lmao either way. I'm also doing some prototypes as well. Full aluminum valve cover with ls ccv and a full aluminum swarl flate delete plate with a bigger intake manifold. I ported my heads more since I'm doing my fab work my self. So fingers crossed
