hamfactorial
Pelican:
Who at ABC did you email?
So do you suggest that CR TDI owners use or dont use fuel additives?I would like to point out the HPFP on the direct-injected gas engines is a very different animal than the ones used on diesels. There may be a similar type of failure, though. I know on the VAG direct-injected gassers, the HPFP failure was actually at the camshaft that drives it (lubricated by engine oil, not fuel). I do not know the details of the BMW failure.
I'd also like to add that MB's CR diesels, which have been in use in this country (with our supposedly "crappy" fuel) for 5 years seem fine. Just serviced a 260k mile Sprinter yesterday, runs perfectly fine.
A friends Diesel Jeep Liberty is the same way. runs fine not a problem or hiccup to it. (a Mercedes powerplant)I'd also like to add that MB's CR diesels, which have been in use in this country (with our supposedly "crappy" fuel) for 5 years seem fine. Just serviced a 260k mile Sprinter yesterday, runs perfectly fine.
That is not an MB engine... it is a VM Motori engine (from Italy). But yes, they seem to burn our fuel OK too.A friends Diesel Jeep Liberty is the same way. runs fine not a problem or hiccup to it. (a Mercedes powerplant)
maybe VW is using cheaper alloy metals than MB uses?
Seems like there are a fair number of people running WVO as well as the higher concentrations of bio also. Seems like the weak points on those jeeps as far as the drivetrain goes are not engine related either. Outside of a weak torque converter in the transmissions and poor lift pump in the tank, the overall drivetrain seems to do pretty well in them.That is not an MB engine... it is a VM Motori engine (from Italy). But yes, they seem to burn our fuel OK too.
ferland25 had analysis done. Unfortunalely, ferland25 stopped posting shortly after these 2 posts.dweisel:
Looks like another victim, but warranty covered it:
http://forums.tdiclub.com/showthread.php?t=298226
On the above post, I don't recall reading if anyone has had the metal particles analyzed on an atomic absorption unit (or other emission spectrometer) to see if they are aluminum, steel or a combo of both?
From everything in any of the posts, ever, on this site about the HPFP failure, it has resemblance of being chronic failure and not acute. That means that the failure is due to continuous degradation.I just got another complete tooefed fuel system from a contact at a local dealer. VOA pawned that one off on the owner's insurance company, despite the little fuel testing setup clearly showing it was nothing but #2 diesel in the tank.
Gonna take the HPFP apart this evening.
Agreed 100% however, to play devils advocate the dealer must check the current fuel in the tank to make sure that it is in fact diesel fuel. What if someones HFPF failed and that person mistakenly put regular petrol in the car and that petrol was still in the tank? Surely that would be cause for VW not to cover the warranty no?I really wish people would look past the most recent tank of fuel.
IIRC, once "bad fuel" is in the system and flows through a HPFP, the pump fails very quickly, like within few short miles driven on "bad fuel". from what I read on the forum, it seems that CR fuel system is way less forgetting compared to older designs.From everything in any of the posts, ever, on this site about the HPFP failure, it has resemblance of being chronic failure and not acute. That means that the failure is due to continuous degradation.
Why is this important?
It's important because the "bad fuel" will NOT be from the most recent fuel tank. Chances are that it was several tanks ago that started the first domino. Of course the most recent tank shows #2 diesel, and will almost always show #2 diesel. It's a p!ss poor test that has little to do with actual operation of the vehicle's past.
I don't agree with this. Most of the failure stories I've read start with "filled up the car, drove for a bit, got a flashing glow plug and check engine light," or "filled up, drove a bit, stopped the car and it would not restart."From everything in any of the posts, ever, on this site about the HPFP failure, it has resemblance of being chronic failure and not acute. That means that the failure is due to continuous degradation
What if you only got a tank of "semi bad fuel" IE bad lubrication. You were able to go through the full tank of semi bad fuel no problem, yet two tanks down the road you're stranded. Kinda hard to peg it down at which tank was bad. I seem to remmeber people having put 200-400 miles on a tank and then having it fail.IIRC, once "bad fuel" is in the system and flows through a HPFP, the pump fails very quickly, like within few short miles driven on "bad fuel". from what I read on the forum, it seems that CR fuel system is way less forgetting compared to older designs.
So the "first domino" is the last one... There is very short time, if any, between "bad fuel" use and failure.
Agree. VW, however, is using "bad fuel" as a reason... not gas in the tank. Bad fuel is quite an ambiguous statement .Agreed 100% however, to play devils advocate the dealer must check the current fuel in the tank to make sure that it is in fact diesel fuel. What if someones HFPF failed and that person mistakenly put regular petrol in the car and that petrol was still in the tank? Surely that would be cause for VW not to cover the warranty no?
So, then, how did so many goe an HPFP failure on half a tank burned through? Nobody has tested failure modes on these forums.IIRC, once "bad fuel" is in the system and flows through a HPFP, the pump fails very quickly, like within few short miles driven on "bad fuel". from what I read on the forum, it seems that CR fuel system is way less forgetting compared to older designs.
There seems to be a fair mix of scenarios, with little trending in any direction (right after fill up, or half-way through a tank). I will state that if it is the most recent tank, then the fuel could be tested for all perameters (lubricity, content, particulates, pH, etc) that would be out of ATSM spec for diesel.I don't agree with this. Most of the failure stories I've read start with "filled up the car, drove for a bit, got a flashing glow plug and check engine light," or "filled up, drove a bit, stopped the car and it would not restart."
Not saying it isn't a progressive failure, but it seems that the failure event frequently occurs right after getting new fuel.
But they (VOA) still warrantied it..... It's too bad we all don't work as car magazine editors.
The first HPFP failure I read about was the PM magazine report of the
failure of their test-car in the June 2009 issue IF I recall correctly?
According to Ben Stewart, the PM editor who drove that vehicle, he said he thought
that it had gotten a bad tank of fuel down in Calixico California and then traveled all
the way to his home in the greater Los Angeles area, and that the next morning is
when their troubles started.
Now this is approximately 221.73 miles, so IF that fuel was indeed purchased in Calixico,
that '09 was able to travel some distance before that tank caused said failure.
That car had only 5K miles at the time it quit, so who knows?
A CASE OF: Which came first, the chicken or the egg?
D
But they (VOA) still warrantied it. It's too bad we all don't work as car magazine editors.
Approximately?
Now this is approximately 221.73 miles, so IF that 'bad' fuel was indeed purchased in Calixico,...
