joshferrer
So with lots of time on my hands the last few months...I have been looking into cooling upgrades for my CKRA and would appreciate some input from you experienced guys here.
Goal: Reduce intake air temperatures and upgrade cooling capacity while in there.
There aren’t any “upgrades” for this platform as the stock charge cooler system seems to be pretty efficient as is but I haven’t been able to find hard data on this. Pretty good stock efficiency of this platform seems to be the consensus here in my searches but would love to be pointed to that as I can’t seem to find it.
Where can I find info on the stock Intercooler on this platform? (CFM, core size, etc)
Part: 3AA145805B
Has anybody here tried upgrading any part of their stock air to water setup on the CR and compared that data to the stock setup? Let’s say I find something more efficient than the stock setup and install it, theoretically the IATs should be lower. Since it’s all electronic, does the ECU recognize that lower IAT and adjust accordingly? I need help understanding how it works on this platform.
Thinking of upgrading parts of the system just to see and compare data. I do autox and canyon drive my TDI as well as sit in absurd amounts of traffic here in LA so it wouldn’t hurt to be able to lower IATs and also keep engine coolant temps lower.
Here’s what I’m thinking:
I’ll try this in two phases.
Phase 1: keep the stock Intercooler. Replace the stock auxiliary water pump to something that flows more like a Bosch Cobra or something. Take both the radiator and the auxiliary (heat exchanger) radiator out from the core support. Get a front mounted heat exchanger. Since now there is more space in the core support area, get something like a beefy upgraded MK7 radiator and just weld the mounting points to fit this core support.
Phase 2: try a different upgraded air to water intercooler (pending on if on paper it really is more efficient than the stock one).
If I do phase 1 alone, that should help with my goal, right?
Info on my current power setup:
Currently on a Malone stage 2 dpf/egr/def delete tune and should be right around the 200hp range. The reason I’m looking into this is because I’m working on a build to hopefully get it to around 300hp. My timing failure earlier this year has me with a second CR engine around now that is going to be used for this build. It’s a slow process that has gotten slower due to Covid. Doesn’t hurt to start working on understanding this cooling thing now.
I’ll be logging data in the coming weeks as I’d like to see where my stock IATs are here in SoCal.
Has anybody here done anything like this and have data they’re willing to share? Is there already data here that I missed? Please point me in the right direction. Should I even attempt?
If there isn’t data out here, I’d be more than willing to be the guinea pig on this.
I’m not expert by any stretch of the imagination (you can see all my failures in threads lol) so I’m open to all comments, criticism and help. I would really appreciate it!
To anyone responding, I do realize that the difference may not be significant enough or even “worth it” to try but definitely would love to learn how it affects this stock setup. This is definitely not something to brag about but just something cool to learn from, in my opinion.
Thanks!
-2014 Passat TDI SEL
Part: 3AA145805B
Thanks!
