Whitbread
I posted a thread in the motorsports section about the two projects I'm going to be involved with at work, but have some specifics that I feel are better addressed here.
This is the car engine will be going in http://superlitecars.com/gallery-slc/
Engine will be a 2009 CBEA motor bolted to an Audi 01E trans. Gear ratios will put us at 1800rpm at 65mph, the planned speed range for the mileage run. Car will weigh 2200lbs. Space, emissions, custom fabrication/machining are of no concern as budget and resources are pretty much unlimited.
Customer requirements of the project:
#1 - Car must drive from coast to coast on one tank of fuel to set mileage and distance record. Fuel tank will be approximately 60-65 gallons. Shortest distance coast to coast is about 2100 miles. Aero mods will be done on front end to front of car to make it more slippery and no wing.
#2 - Car must perform in same league as it would with an LS3 crate engine on demand once mileage runs are done. If it's not a riot to drive, it will turn this whole poject into a flop. It doesn't have to run next to it, it just can't be an 1/8 mile behind in a 1/4 mile drag race.
Plan #1
Stock long block
2260vk turbo
cp3 pump for durability sake
Intercooler
Plan #2
Rosten rods
Stock pistons
Head porting
Cams
Head Studs
Cp3 pump
Larger nozzles
stock turbo as Hp unit
EFR 7064, EFR 6758, or a GT2876R LP turbo
I'm leaning towards plan 2 as long as customer is ok with budget, but mileage cannot suffer. I know low CR alh's drop mpg, but theoretically, since I'm not changing CR, mpg should be relatively unaffected I think. This here is the reason for this post. I'd like to hear the input of any engineers thoughts or tuners that have messed with the CR platform.
Plan #1
Stock long block
2260vk turbo
Intercooler
Plan #2
Rosten rods
Stock pistons
Head porting
Cams
Head Studs
Cp3 pump
Larger nozzles
