JDM Mike 02
For anyone that’s installed a CP3 pump on your CRUA, did you swap over a different pump gear? The kit I got from dark side has an adapter for a gear that bolts on to it but my factory gear does not bolt on. It’s two pieces but seems the first piece is pressed on to the shaft of the pump while the second is held in place by the center nut.
