Paulinski
AWESOME Andrew!!!!
I have to admit that this made me laugh.I keep throwing money at my screen but nothing is happening!
Sent from my LG G3 using Tapatalk
The ECM will balance each cylinder to make them equal. If one cylinder is off it will back off the fuel on the others to make them equal. It will do this until it outside of a set range of how far the cylinder can be off.I think that's less of an issue here. I'm curious of the drive ratio of the CP1H the Cruze's use. Some accumulator may be required for the best performance, but I'm sure they'll notice a performance detriment soon if that's the case, since these are on the road now.
You could likely look at cylinder balance values to see if one was contributing less, but unlike the CP4.2 swap, this isn't really about the added fuel capability. Even if the pulses are not ideal, if this pump runs the engine in stock or tuned capacity, that's all most need. This swap is primarily about reliability, not performance.
Wow! It's been a while, thanks for asking Joe!!Bump
Any updates?
CP3 Pumps seem to be the fix according to Andrew he's been running one for over 25K with no problems. Not a cheap upgrade though it can vary used vs new vs remanufactured. I think ID parts sells the Liberty CRD 2.8 Bosch pump new for $1200 if I remember correctly.
Agreed!Can't ask for a better update than this! Thanks 2micron for all your hard work on this pump upgrade.
Good work Andrew! Any chance of a turn-key solution coming from you any time soon?Yes, ~26k miles, a great cold winter and zero issues.
The pump is awesome and works good. I often forget it's even there, but still get a faint reminder with the gear whine from the feed pump.
In the fall I was running tests, logs, monitoring mileage etc!! No drama, I just drive the car to work now and forget about the pump.
We went on a big family trip a couple weeks after install, pretty remote areas up north with full confidence.
This winter was great for "extreme" testing as the temperature has been colder than normal. I did notice the car starts with less cranks than before. The CP3 pump builds pressure with less rotation than the CP4.
Fuel mileage is no different.
Maybe not mentioned in the past, the electric Aux pump is long removed as the CP3 pump I use has its own gear driven feed pump. The in tank lift pump is still there, simply feeding the pump. I also run the 2Microntech "contain flow" filter as a 1micron pre filter, after the factory filter. Not required, but it feels great feeding super polished fuel!!!
My car is bone stock, no tune or other upgrades.
These pumps are very plentiful and avaiable in Europe. Dozens of small cars use them.
Thanks for asking!!
Andrew
UH Oh.....Hey 2micron, I sent you a PM
