Thanks for the info, perhaps I can relax a bit then. What tune are you running from Malone?My highest pressure is about 1920 Bar as well. On my Malone ticket I was told fueling is correct.
I am using 0445010042 pump with 0 928 400 643 FMV, pump was purchased from Nerings.
whoops, overlooked your question. CP3 was done at 25k miles in 2019 and now approaching 200k miles on engine which means 175k miles on the CP3 itself. zero issues.How many miles have you put on the pump?
There are some very expert people in this cp3 subject but I will give you my personal opinion, if you're wanting to upgrade to cp3 and you do so with the recommended fuel metering valve which is already discussed in this thread you shouldn't need to recode for anything. It will run with your stock setup perfectly fine.I just purchased the parts to do the timing belt on my 2013 A3 which has 102k mi on the clock, and was thinking about the CP3 "upgrade" as well. I'm in no rush as I have a quite a few miles left before the interval, and the weather is quite mild here easing the 10yr requirement, but want to do it sometime this year. I've read the last 20ish pages of this thread, and 2 main questions come up for me:
1) How likely is it that i can do this without having problems needing to recode. Since I am in california, tuner codes can be a big problem for smog, and while a lot of the more recent installers in this thread have had successful installs (and some very dramatically not!), the majority of them seem to have had some sort of problem that was resolved by an ECU tune update. I'd love to have that option, but just not sure i do.
2) In reading about lots of these problems, have these kits, even though there are more options, become inherently riskier, or are lots people quietly, successfully, doing this install and we only hear about the bad stuff because... internet?
Thanks!
a tune will be neededI want a no drama, no code, no limp mode, no change in MPG and smooth running modification.
Thanks I have mild stage 0.5 tune. They (Tunezilla/Malone) offer a CP3 tune add on.a tune will be needed
the "plug and play" kits will "run" but you might get some weirdness during certain RPM at certain load
you can actually buy a CP3 R70/R90 brand new right from auto part stores.Thanks I have mild stage 0.5 tune. They (Tunezilla/Malone) offer a CP3 tune add on.
Seems this mod is a bit finicky and affects cars with a lot of mods, hot tunes, larger turbo, deletes.
I really want a new pump not used or rebuild. Any ideas?
