It's ok like that, trust me!seeing this, https://imgbb.com/8rK2bFC
got me concerned. there SHOULD be no GAP between the mounting frame to the CP3.
You may have missed "notching" off the bracket on the top near the CP3.
go to page 7 and 8. this will show you how it SHOULD LOOK like properly installed. kudos to you for doing it all.
Is it the correslct fmv that's required? Or is it just the one that came on the pump that came from the salvage yard.. who did you buy the kit from?Good afternoon ! Just looking for a little help and I know people here are pros. Just installed a cp3 on a 11 jsw, but it is only getting 8 to 16 bar when trying to start which it is near impossible. Feathering the accelerator has got it started a few times. Blowing white smoke throwing codes for too low fuel pressure in the rail. Curious if the fmv on the pump is bad ? It's the 1.4 Citroen puegot fmv. Car has a stage stage 2 tune tune from malone and cp3 tune also They said it sounds mechanical but gave me nothing else. Can't seem to find any info anywhere of anyone having this issue. Lost what to try next to get it running. Any info or tips to try would be greatly appreciated. Thanks for your help.
Part number for the fmv is 0 928 400 643. Asking around that is the "compatible" fmv according to folks. Kit came from diesel DNA tuning. Have been it contact with them for months now. They think it's the fmv, however, they said they have contacted the manufacturer and are showing them the data logs from the car. But after 2 months there is still no resolve as they are waiting for the manufacturer, bosch, to get back to them. That's why I'm reaching out to hear if anyone else has any ideas. When the car runs, which we had to fill the fuel rail manually to do so to get some data, the actual vs supplied pressure in the rail is not equal.Is it the correslct fmv that's required? Or is it just the one that came on the pump that came from the salvage yard.. who did you buy the kit from?
Well tell them to send you a replacement fmvPart number for the fmv is 0 928 400 643. Asking around that is the "compatible" fmv according to folks. Kit came from diesel DNA tuning. Have been it contact with them for months now. They think it's the fmv, however, they said they have contacted the manufacturer and are showing them the data logs from the car. But after 2 months there is still no resolve as they are waiting for the manufacturer, bosch, to get back to them. That's why I'm reaching out to hear if anyone else has any ideas. When the car runs, which we had to fill the fuel rail manually to do so to get some data, the actual vs supplied pressure in the rail is not equal.
well i did and this was the response,Well tell them to send you a replacement fmv
0928400643 that's the one for the fmv I havewell i did and this was the response,
"Hello Jason,
We haven't heard back from the manufacturer since you sent the logs yet. Hopefully he can pinpoint it. I really doubt it's a bad pump. I have only ever seen one that needed changing in the thousands we have seen go out and it was because a piece wasn't pressed in properly and eventually worked its way out. but the car never have a problem running or starting even with a hole the size of a quarter in the pump. As soon as I we hear back from him we'll let you know."
so this is why i'm asking if anyone has other ideas or knows if it is definitely the fmv. thanks
finally got the car running thanks to Andrew "two micron !" wasn't the fmv at all. He diagnosed it as one or more leaky injectors, and upon replacing them the car started right up. anyone having a white smoke, no fuel pressure at the rail might want to start there. Andrew is the man !0928400643 that's the one for the fmv I have
Do you know of any in US that would have the one we need? The Cummins maybe? Or Jeep diesel?There is a huge variety of CP3 pumps. The one I know of that Andrew discovered works is a R70 pump from some Peugeot and Citroen models. Probably not going to find many of those in US junkyards.
Nope, not unless you're a brilliant fabricator. Not worth it. Andrew started out on that route before discovering the right pump that bolts up with minimal work to adapt. Keep it simple.Do you know of any in US that would have the one we need? The Cummins maybe? Or Jeep diesel?
try Ebay. plenty of them still there.Do you know of any in US that would have the one we need? The Cummins maybe? Or Jeep diesel?
All that I've seen come from the UK. Still have to buy or make the adapter plate and pully adaptertry Ebay. plenty of them still there.
Do you happen to have the actual part numbers? Like I see Bosch has "0986437303" and that's for a sierra but I am unsure where to find the one for Peugeot and citroenThere is a huge variety of CP3 pumps. The one I know of that Andrew discovered works is a R70 pump from some Peugeot and Citroen models. Probably not going to find many of those in US junkyards.
I think he mentioned mine was from a Smart car in Canada. The metering valve and its internal piston is the key to having these work correctly with minimal or no tuning.There is a huge variety of CP3 pumps. The one I know of that Andrew discovered works is a R70 pump from some Peugeot and Citroen models. Probably not going to find many of those in US junkyards.
Interesting- I didn't even know they made diesel smart cars. I was pretty stoked that the kit Andrew sent didn't require any tuning after installation.I think he mentioned mine was from a Smart car in Canada. The metering valve and its internal piston is the key to having these work correctly with minimal or no tuning.
I had the part number at one time, but ..... I think you can get that from Matt Whitbread.Do you happen to have the actual part numbers? Like I see Bosch has "0986437303" and that's for a sierra but I am unsure where to find the one for Peugeot and citroen
9637317380 is the pn of my cp3. Still need an adapter plateDo you happen to have the actual part numbers? Like I see Bosch has "0986437303" and that's for a sierra but I am unsure where to find the one for Peugeot and citroen
part number i listed is the pump i was sold. which is also the same pump....Correct fuel meter valve is 928 400 643
Cp3 would be
0445010042
Citroen / Peugeot 1.4
Also known as 1920EC
adapter plate can be obtained by Matt whitbread aka whitbread performance.
I gotcha.I am trying to help![]()
yep it’s all good. Been there and done that. Glad you didn’t shoot the messenger LOLI gotcha.
Dealing with a self ritous samily member. Didn't realize you were listing a different part number for the same pump till later. I also have the same fmv part number.
