Norman57
06 Jetta 1.9 BRM engine , installed new set of fans, power wire has power, ground is good, 1 small wire has power when key is on, other wire is the one that starts the fans, where does this wire get its power from?
You said you've tested the other 3 wires... so I would assume that you know what color the one small wire you tested was no?If the yellow purple is the one that turns the fan on, then yes
100%. Which is why OP needs to run the fan output test in VCDS as you recommended earlier and go from there.It may provide a ground to turn the fans on. In any case, the ECU controls the fans or is supposed to.
