Lane_S
For the past 2 years I had an issue with low coolant temps which I guessed might be a bad thermostat. This month I replaced the thermostat with a 195 Deg. unit and changed to Evans waterless coolant. I also made sure to test the AC/Fan issue as described in another thread. I have Ultraguage to monitor temps. After changing the thermostat and coolant I noticed hotter temps up to 212 Deg. I tested the fans with a jumper and they work. I then changed out the temp sensor( Green 4 pin) and the temp switch in the radiator (3 blade) but still have the high temps and the fans will not activate low or high speed. What is my next move to diagnose this?
