does anyone have a wiring diagram for the cooling fans on a 2014 jetta TDI
my fans work, they both run when i do output test in VCDS, they both run when it warms up. the wife has complained the ac stops working when in drive though.
previous owner changed the fan because it got jammed with animal nest. not sure if its the correct part number.
i am getting the following codes
p1946
p0691
i don't want to replace the fan if its not the problem. seems weird that the fan is actually working but has codes present stating that it shouldn't be..
p1946
p0691
