TDIRyan
I just want to confirm that I'm getting the right parts here. I need a coolant temp sensor and probably will get a set of glowplugs. I have 87K on mine, and they are original plugs and I have an intermittent signal on the #1 plug and the coolant sensor.
Is this the correct temp sensor:
http://www.autohausaz.com/search/product.aspx?sid=gyruhkvud0uaau55ct20ncum&makeid=800026@VW&modelid=1389214@JETTA%20TDI&year=2002&cid=coolant@coolant&gid=4308@Coolant%20Temperature%20Switch
How often should you replace the glowplugs?
